Best Driver's Side Lean Correction Spacer for use with Toytec Ultimate Lift?
EdmundGTP
Member
Just like the title says, looking for some input on this. Seems different thickness spacers work better/worse depending on which lift is used.
Thanks in advance!
Ultimate Lift? Aren't those a fully height adjustable unit?
He's talking about a rear spacer on the drivers side to correct the lean due too the weight of the gas tank and battery. Most people are happy with a 1.5" Daystar spacer.
Correct. I do have an OME 10mm shim that I haven't tried yet. 1.5" seems pretty drastic to me for some reason.
I personally didn't notice a difference when I had the 10mm shim.
For some reason the 1.5" spacer doesn't result in being 1.5" taller, I guess the springs compress more. I installed one for [MENTION=72004]deedst4r[/MENTION] on saturday and it was actually still just barely low on the driver's side.
Another option would be a custom spacer from cornfed, I believe they run about $40-50 and will make them any height your request.
Good input. Thanks. I'll try the 1.5'er then. Does any vendor sell them as singles instead of pairs?
I've got a single one for sale if you're interested, $25 shipped. Also have the 10mm trim packer, $15. I'd do both for $35. I believe you can stack the 10mm spacers, although I'm not sure that's the best solution. I ordered a single 3/4" spacer from Cornfed, it was $40 shipped.
Also, here's a good thread on the topic: rear spacers? - Toyota 120 Platforms Forum
Double stacking the 10mm's do work, I didn't like that idea though.
Jhunt
