Best gas mileage
LeonAzul
Today I hit 304 miles on 15.5 gallons just shy of 20 MPG'S. First time I get this great mileage on a single tank. A small tune-up does a world of change. I also purchased new Firestone Destination A/T, 265/75-16 and did an alignment a month ago. I am very pleased on how the 4R is running!
The best I have done is 23.2. That is on p rated 265/70/17's running 40 psi. I did not go over 65 or stop until it was time to fill up again.
My personal best was 23 and change. Spark plugs, O2 sensors, cleaned MAF were the things I did.
Cruise control always on highway helps get your MPGs up there.
I got 17.3 driving 1400 miles one time. That was on 33" tires at 50psi. I wish i could get what you guys get.
I need to check the psi.
I changed the spark plugs and wires with NKG's. Replaced the fuel filter, air filter, swapped out the O2 with a used one I had laying around. I was forgetting, I installed a used OEM muffler around a month ago as well. I should have cleaned the MAF, I'll do that this weekend.
I always use cruise control on the highway. I'm getting about 19 mpg in my 98 on 265/70/16. My '00 got at best 17 mpg
Meanwhile my old man is still trucking along at 12-13 mpg in his '01 Ram - the 5.9L is a killer
I usually get between 18-19 city when I'm driving an automatic. When I have a 5 Speed I only get 17. Perhaps I'm a little heavy winding the gears out.
patnewton
