Best option for factory spring replacement?
Charlievee
Senior Member
I have been reading suspension threads all day and still no closer to an answer. I'm looking for options to get rid of the nose diving soft springs on my ORP. It's starting to drive me nuts. My First idea was to go with the Eibach kit, but it would be awhile down the road. Has anyone done other options then a lift to correct the issue? Is there a factory spring that can be had? Truck rides like a caddy and all the floating is absurd.
on the cheap and quick I fabricated 3 spring spacers put 2 on pass side on the lower portion of spring on driver side 1 bigger spring spacer ..
pass side spring is softer driver side harder..
also bleed the rear brakes could be air in the rear brake lines.
I had all this ,but it is fixed now on the cheap..
Eiback all the way you will love the way it handles.
Cpn2mss
