Best replacement shocks?
I still hold to my statement. Probably because the shocks are sharing the fluid, instead of 4 individual shocks, it's a system. It "ramps up" when needed.
agree to disagree. the bilsteins are an absolute driving upgrade to xreas. i won't even get into the quality of the shock body itself either. go bilstein. well done.
Here's the result. The street slopes down a little. Currently the fronts are adjusted 1 notch up.
4runner03.jpg~original
4runner02.jpg~original
4runner01.jpg~original
That looks great, exactly what I want!!! I'm guessing you're at ~1.5 inches of lift with that setup (am I close?). The second notch up on the shocks should be 1.75 inches of lift, so it'll be very close if I don't go with the FJC springs. Thanks for posting the pics.
Bringing this back from the dead...
My XREAS system has reached the end of its long 163,000 mile life. Time to look for new shocks/struts/springs.
I do not have the time or desire to mess with the front struts and springs, so I am considering the KYB quick struts as a front with KYB shocks and Moog springs on the back.
More Information for KYB SR4131
I want to keep the stock height and close to stock ride feel. The only reason I am not considering bilstein 4600's is because I don't want to mess with the springs in the front, and I think the springs need to be replaced as well due to the mileage.
Thoughts? I never intend to lift this truck.
How did yours turn out did you go with KYB up front? How did they hold up?
Im looking to do the same with the KYB quick strut. Any feedback from someone who's gone this route would be much appreciated.
Wanted to drop an update. I did the swap. I removed the original XREAS system and installed new KYB struts/shocks with Moog springs in the rear. I used the KYB complete strut plus assembly More Information for KYB SR4131 for the front and paired the moog springs with the KYB rear shocks.
I could not be happier with the ride. It drives like a dream! I cant believe the difference in ride quality. I kept everything stock. My wife drove it and commented on how nice it drives now. It feels like a new truck.
I also recently did the sway bar bushings upgrade but changing the shocks was what really improved the ride. I wish I had done this swap earlier.
Hi Ben...looking to do the same thing to my 2003.
I see you went with the KYB SR4130/SR4131, for the front.
What exactly did you go with, for the rear?
Your help would be awesome!
UPDATE: Actually, I just found your info, in another thread. Thanks!
Here's the thread, for anyone looking for it, too... http://www.toyota-4runner.org/4th-gen-t4rs/199146-xreas-replacement-whats-simplest-solution.html
Glad you found it. I knew I had posted it somewhere. I bought the parts and had my local shop do the swap for me. They said it was simple. I had wanted to try it myself but just didn't have the time to do all 4 corners in one shot... which is what you have to do since they are paired together. I have been very happy with the swap.
I ordered the parts last night...should have this done in the next 2 weeks.
I'll check back and let you know how it goes.
Thanks for the info! :clap2:
Ok...everything has been changed out...and rides great!!
Sits a little higher, due to the springs...and I like it a lot.
Also changed out both front wheel bearings, as one was starting to make noise.
Slapped some new sneakers on, too...that I had ordered last year.
This thing is like new now!!
But, looking to replace it soon. Looking to pickup an FJ Cruiser.
My son will probably end up with the 4Runner.
Thanks for the info...this was a great option to replace the XREAS system.
Did this level the vehicle or did it just raise it up a bit?
Not sure exactly what it was before the change...and not exactly sure where you should measure from.
But, I measured from the ground up to the top opening of the wheel well (outside edge).
I came up with 35-1/8"H in front...and 35-3/8"H in rear. Does this make sense? So, 1/4" higher in the rear.
When you order the KYB (or anything else, for that matter) is all of the installation hardware included, or must it be purchased separately? I'm thinking of having to take a sawzall to one of the bolts. Can't put it back together without new hardware. and, is the replacement hardware brand specific? Sorry if this is a dumb question...
didn't read the whole thread so if this has been covered please disregard.
For ride quality and budget concerned: Monroe OESpectrum are really nice when ditching X-REAS.
Bought mine from Rockauto, great price (currently a rebate too) simple bolt in, rides nicer than my jetta (1.5 drop on Koni Orange so not much of a surprise)
