Best Tire size for 3 inch lift
jak3_t
I'm looking to get new tires for my 4runner it has a 3-inch lift and I am currently running 275/70R 17. The problem I have with these tires is I find they are way too wide and in being so wide the previous owner has put wheel spacers on and that's causing me to have to change axle seals like crazy. I'm not looking for the biggest tire I can fit, just something not too wide so I can remove the wheel spacers, looks good with a 3-inch lift and that has a bit better mileage.
275 is not a wide tire at all- less than 1/2" wider than stock width. That shouldn't cause any rubbing on stock wheels.
Obviously you aren't running stock wheels, as they are 17's. What wheels are you running?
I wouldn't run a tire any smaller than a 275/70 with a 3" lift, but I am running 315/70R17 on a 2.5" lift; I like to be as low as I can.
Are you sure the wheel spacers are necessary? Where are the tires rubbing?
I am running 235/85-16s with my ToyTec lift at 2.5". I really like the profile of the tire and height for DD use. I have had no problems off road in different conditions and it handles fine on road so I have everything I need in the one tire size. YMMV
The width of your tires should not be the cause of your blown axle seals. The specifications of your wheels have a lot to do with rubbing issues and where the overall tire wheel combo moves throughout the wheel well. Perhaps you could take a look up what specifications you are running for your wheel and what size wheel spacer you are using to accommodate your tire choices.
I would say, overall, 285s are the most run sizes for the average 3" lifted 4runner. Some run a slightly taller and slightly more narrow 255/80/17 depending on their wants and needs. And a few run larger tires. Some even run the smaller 265/70/17s and are happy.
As long as you aren't doing anything too extreme as far as wheel specs, sticking out way too far, of sucked in way too close, you should be okay.
Got pics?
I meant to address this too.
But he said it's the wheel spacers- not the tire width.
If the seals are being properly replaced with quality parts- and still not lasting- your axle housing is likely bent.
How many times have they been replaced? And how long have you owned it?
I actually never tried running my tires without the wheel spacer I always assumed that's why the previous owner put them on. I also only changed 2 seals (the rear passenger side and front driver side) within a month period, and now my front passenger side is gone so I guess they all go around the same time but I was always told that the wheel spacer will cause axle seals and wheel bearings to go.
Front seals? What front seals?
Yeah, never knew there were front seals...Either way im in the same boat. Thinking of going up to a 17" rim. Want to run a decent tire size, considering I have a 3" lift kit from toytech coming.. Any suggestions? Also should I be changing my UCA?
Sent from my SM-J727VPP using Tapatalk
A c-load 275/70/17 would be nice.
I good size, lighter weight, and affordable that won't necessitate lower gearing
This is paddlenbike's rig that has a really nice stance
Hey there- really love the stance on this one, I know these wheels are the Sequoia wheels, but can someone tell me what size lift and tire/
I run 255/85/R16 Toyo mud tires with the stock wheels. In my opinion the 255 "thin" tires look amazing. It's a 33.5 inch tire. I have more than 3 inch lift but I'm pretty sure you can fit them.
TireSizeDB
