Big Brake Kit for 03-05
mysticz
Member
Anyone know any good brands that make this kit for a T4R 03-05?
Someone mentioned stoptech but when I did a search on there online site, it said they do not make the kit for that model and year.
I see no replies. The brakes on the Sports Edition (LTD is same as SR5 apparently) are 1" or so larger --- hence the larger wheels required to clear the calipers. I'm happy with the brakes on my '03 SE - with replacement of OEM tires and new pads - suspect I'll be even more satisfied. Fronts are 338mm and rears are 312mm.
Thanks for the replies guys, I think with my 20 inch rims I might need a little extra brake power.
Think I checked stop tech but it said none available for my model and year but I will check again.
while they might not show up on Stoptechs site...they still lack alot of info from when they redid their website last year...but
http://www.zeckhausen.com/Toyota/4Runner.htm
Dave Zeckhausen is a personal friend of mine and one of the most standup guys in automotive aftermarket. I have trusted NO ONE else with brakes on all my cars since I started dealing with him.
Honest, you wont need a BBK for your rig...swapping over to higher Cf pads (axxis ultimates), running Stainless Steel Brake Lines and swapping over to a high quality Dot 4 fluid will net you nearly all the performance improvments of the stop tech system for 1/6th the amount.
I run the upgrades listed above and have recommended them to others here on the board looking for serious stopping power here on the board.
