Bigger battery? Climate Control display dimming
StupidMuphin
Hi everyone,
I am getting a lot of light dimming in my 99 limited now that I installed a higher powered headunit. If my headlights are on as well as a blinker, I can visibly watch the climate control lights fade in and out. I have wired an amp to my battery as well as a cb radio, but before this headunit I had minimal dimming, barely noticeable. Would it be worthwhile to invest in a bigger battery? I was thinking Interstate (MT7-75DT). The idle was pretty rough before, but now it is better.
I am pretty bamboozled and do not know what to do. Any opinions or thoughts? It may be the wiring, but it would only be iffy grounds at best which I double checked. I also do plan on adding some extra lights eventually (fog lights, lightbar, etc..). Thanks!
The battery is probably not the issue, it'll be something in the charging system. You are probably seeing the voltage go down to normal battery voltage (dropping from ~14V to ~12.6V or 12.8V).
NegroTundra's suggestion on the big 3 upgrade is a good idea.
-Charlie
Tx470
