Bilstein 5100 kit with stock springs
jb24dolphins
Does anyone have a picture of them running this kit with no spacers or anything done to the stock springs? Also, what setting are you using on the stock to level the rig out and what tire size can you clear easily?
There's a ton of pics on here and a whole thread dedicated to them - also set to .85 in front will level it regardless of tire size
I did the 1.75 setting with a 1.5 inch daystar rear spacer and all stock springs. Rides great, 285/70r17 or 275/70r18 I had to remove mud flaps. Trim front and move splash fender guards forward about a inch.
5100's set at .85 gives a perfectly level frame but slight fender rake. It you go any higher than .85 you need a rear spacer or you will look silly with reverse frame rake.
Here is mine at .85, stock tire size.
<a href="http://s179.photobucket.com/user/therace/media/P1050116_zpsclggugnd.jpg.html" target="_blank"><img src="http://i179.photobucket.com/albums/w312/therace/P1050116_zpsclggugnd.jpg" border="0" alt=" photo P1050116_zpsclggugnd.jpg"/></a>
Here is the quick answer for you that many people have stated about the 5100's in previous threads.
Setting:
.85" front, no rear spacer
1.75" front, 1" rear spacer
2.5" front, 1.5" rear spacer
And this is with stock springs!
Don't work too hard today!
patnewton
