Just to clarify this, especially for you since it appears you are an engineer.
1) 70 lbs on the roof is not the same as 150 lbs in the passenger compartment. And 150lbs in the passenger compartment + 70 lbs on the roof is way worse.
2) I went back and did some calculations of my own.
2010 4runner has a shitty rollover rating (static stability factor = 1.12)
2010 Toyota 4Runner Safety & Crash Test Ratings - Motor Trend Magazine
2010 Toyota 4Runner Crash Tests, Results, & Safety Ratings at Autobuyguide.com
Toyota 4Runner 4-DR. w/SAB Car Safety Ratings
Now based on this number, one can get the 4runner's center of gravity figure, witch is 0.7165 meters with the conversions and a known equation.
Rollover Prevention Docket No. NHTSA-2000-6859 RIN 2127-AC64
Changes in center of gravity is an important value in cargo shipping, so equations to calculate the shifts are readily available. Here is one link with descriptions.
http://thenauticalsite.com/Nautical...bility-Lesson04-MovementOfCentreOfGravity.htm
Now look at vertical weight additions and removals section. Plug in the numbers for our 4runner remembering that our CG (center of gravity) is 0.7165 meters to start with. With base weight of 4750lbs (2154 x10^6 grams) and the final weight of adding 70 lbs, 4830 (2191 x10^6 grams). Do the calculation and you get a final CG (center of gravity) of 0.73976 meters. Now the increase in CG does not sound much, but please place it back to the static stability factor (SSF) calculation equation and you get SSF of 1.084 down from 1.12
That right there put the 4runner with the Gobi rack at the 2-star rollover rating instead of 3 star.
You can find lost of information about the SSF and rollover probability going back decades. SSF drop of 0.04 is significant. The load limitation of 300lbs on the roof is for the same exact reason, loss in handling capabilities, not the weight itself on the roof- correct me if I am wrong on this.
Hope with helps. .. And I do not have beef with anyone, just do not insult me!
First off, thank you for actually doing some research before blindly replying to me with some witty comment that meant absolutely nothing. Your above post, unlike your original post below, shows that you actually wanted to present some type of factual evidence to back you up instead of dire unsubstantiated claims that it is dangerous to mount a rack to a stock TE as you did below. You have to remember that you are posting in an enthusiast's forum that has many smart (and some looking to get smarter) people here. Some of these guys are amazing with what they have accomplished! Your above post did well to inform those who are curious about such things as "CG' and rollover.
Now, you used the SSF, or Static Stability Factor, as your basis to reinforce your original claim. Good for you! This number is a comparative number for general consumer reference. Never mind that anyone with an IQ above 68 can generally figure out that high and narrow will tip over before short and wide. Our government decided that we needed a number for those people who can't figure that out.
The SSF is a good place to start, but unfortunately it has drawbacks. I told you that I did some quick calculations after your first post and came up with almost negligible results. BTW I said "You, your wife and some luggage" not "150 lbs" unless you both are rail thin and only brought a toothbrush.
The SSF does NOT take into account the actual difference in models, modifications or suspension and tires. They choose the biggest volume seller and in this case it is the SR5. They will lump the LE and TE into that same SSF even though they have different suspension controls. They do change for major changes like going from 4th gen to 5th gen but again, do not differentiate models. Also they do not include any vehicle stability controls. To say in a static condition you can tip something over is one thing. To tip it over in a dynamic condition with ABS, VSC and yaw controls actively managing the vehicle is something else entirely. There are many other drawbacks to the SSF but I agree it is a good public consumption number assuming everything else on every vehicle is equal such as tires and suspension. If you really want to calculate it correctly use this
http://www.eng.auburn.edu/~dmbevly/gavlab/pub-pre/A Study of Rollover Propensity.pdf as a guideline.
Even after you calculated the "new" SSF for your 4Runner it still falls into the same general range as most SUV's and older 4Runners here
http://www-nrd.nhtsa.dot.gov/Pubs/809868.pdf in this document.
For additional reading on how vehicle stability control will make a mockery out of the SSF number read this
SUV Rollover in Single Vehicle Crashes and the Influence of ESC and SSF article.
And last but not least, the SSF is only one metric. As important as this number is it is also just as important in determining a rollover risk with your vehicle if you are:
Male or female
Under or over the age of 25
Have been drinking
as evidenced here again in table 3.
So if you are a female under the age of 25 that has been drinking while driving an SUV, you are SOL!
Now, to address the below original post:
Most everyone here knows if you lift it and put some weight on top it will not handle as good as if you dropped it and put some low profile tires on it. You don't need anything but common sense to tell you that. Now, if you did some extensive suspension modifications to it I'm sure you could make it handle better than stock, such as Icon stage 6 or something.
Again, I appreciate you posting the conclusions to your research. Your truck looks nice. I would suggest some better tires that will hopefully negate any feelings of fear in the future when you drive it.
Now it may seem a little weird that I have these 2 in the same thread, but bare with me and you'll know why I wanted these to be together.
First and foremost, I think I may have the record for the fastest Gobi rack order and delivery. I ordered my rack on April 24 and receiver it May 15, that is 3 weeks exactly. No words on how happy I am. The order was through Trail Duty.
Bilstein 5100 lift & review:
front: Bilstein 5100 1.75 inch lift (actual about 2)
rear: sway-a-way rear springs, 1.5 inch lift (actual about 2)
Driving the original 13" Trail w/ KDSS out of the dealer lot, there were a few thing I could feel about the truck's ride and handling. Supple ride, relatively controlled but evident body roll, significant nose dive on hard braking, and an obvious understeer in corners. When swapping the rear springs to SAW and the front shocks to the Bilsteins, the whole ride had changed. The SUV now rode like a light truck, significantly harsher and bouncy, especially at the rear. On the bright side though, 2 things happened: I felt like I was in a BMW X5, minimum to non-existant body roll, nose dive eliminated by about 80%, and more importantly, only slight to no understeer in corners. the truck felt more neutral in corners and wanted to be driven harder. Overall happy with the result, although my wife was disappointed with the ride quality.
Now this is where Gobi comes to play. I received my rack 3 days ago and installed it yesterday. I finalized it with the ladder installation today.
The shockers comes with the change in the ride with the Gobi rack on top. The harshness is essentially eliminated, which is not bad. However, the weight of the rack has changed the center of gravity to such an extreme that the truck feels really unstable with significant body roll in corners, and worse instead of confidence it inspires fear, I am not kidding.
The truck looks awesome with the rack on top, and I wouldn't want it any other way, but anyone else have noticed a change in handling with the rack on top? I am glad I had the suspension mods. I would definitely not recommend the rack without any suspension changes, it could make the ride down right dangerous.
Here are some quick shots I took after the ladder install today
