dullallday
I ended up buying from 3 different companies to avoid lengthy back order wait times.
Where did you get the 6112s from? I've been waiting for mine since November.
I'm in the same boat. I got 6112s with 650lbs springs and I'm still waiting for full skid, slider, slim front bumper. It's going to take a while. Curious to know how is the ride quality without extra weight....
6 month lift report. I’ve put just over 4k miles on, no squeaks, drives is still very smooth. This is a DD, it has seen no serious off road use.
Just took measurements on flat ground and find no settling. Below is before measurement center hub to fender : actual lift achieved - current measurement center hub to fender … current measurement bottom of wheel to fender.
DF 19.5” : +2.25” - 21.75”… 30.625”
PF 19.875” : +2.125” - 22”… 30.875”
DR 21.75” : + 1.25” - 23”… 32”
PR 21.75” : + 1.25” - 23”… 32”
I will be doing this 6112/5160 soon waiting on back order, Im in the process of picking out new wheels and tires, stuck on the tire size, 265, 275, or 285 ??? thinking on going method 701 and bfg / ko2. SOS
i have the 5100s for up front. hoping the 1.75 notch is enough up front to pair with the 1" b12s and 5160s
Hi I was just wondering if you actually finished this build. I already got my 5100s for the front and I set them to the .85. Really close to level but I'm looking to go a little higher in the front in rear. Do you know if 5100 in the front (1.75 setting) and b12 1.5" in the rear is close to level or is there still a rake?
