How hard is it to adjust the height on these once they are already installed? Was hoping that I didn't have to pull them to change clip setting.
Adjustment requires disassembly.
I cant compare to the TRD Pro since I have never driven one. I have driven the KDSS and I own a non-KDSS 4Runner and I will say my 4Runner feels dramatically more stable. Definitely less nose-dive under braking and I have taken it off-road and it is drastically improved.
Is there better systems out there... probably for $$$$$$
No Regrets.
I'm curious any particular way you landed on your choices for the rear shock/coil combo? Or why you went with the ICON 2.0 over 5160's or something?
I find it curious that Bilstein isn't offering alternative instructions for KDSS-equipped vehicles since from what I've read, the "KDSS lean" is typically toward the passenger side (opposite of non-KDSS vehicles).
#Sauce839, maybe you could try just swapping coilover assemblies from side to side without disassembling them or moving clip positions, and see if that levels your 4R out.
So I just installed the 6112's on the front of my TRD offroad (Trail) w/ KDSS.
The installation was fairly straight forward. I put the Sway-a-way 1.5" coils on the back (although its closer to 2":frustyand will install the 5160's once they arrive.
Here is my concern with the specs.
I'm going for the full 2.5" lift on the front, and used the 7/6 setting as shown on the bilstein instructions. But because of the KDSS system, I still have a 1" lean (passenger side is low). Once the rear struts arrive, I'll get the wheel alignment done, and if the system hasn't leveled itself out by then, I'll have the dealership do what they can (ie. bleed the system as recommended by this forum... but expensive if I screw it up). The passenger side may need to come up to the top notch to get help level it out... which means it'll be another couple hours work to pull out the strut, disassemble, move the circlip, assemble and install.
For the assembly of the 6112's, there isn't much room between the spring and strut. The spring compressors I have could not compress the spring enough that I could even start to thread on the top nut. After messing around with it for ~2 hours, I gave up and had a shop assemble everything and I did the install. With the proper tools, it should take 10 minutes to do.
My recommendation... if you have a KDSS equipped vehicle, you may want to look at a threaded coilover (Icon, Toytec, King) just to save the hastle of trying to balance out the system. This had crossed my mind before buying the bilstein set up. I may live to regret it if I can't get this to level out.
The non-KDSS trucks have a driver-side lean so the 6112s are supposed to correct that when set to the Bilstein instructions. If you do that on a KDSS rig you're exaggerating the already present lean.
If you go to the dealer and they measure anything under 0.787" of lean that falls officially within Toyota spec and they won't touch it.
I would bet you could swap your two front 6112s set the way they are and your lean would get better.
Well damn. I sorta wish Bilstein had put that in their instructions.... oh well, I guess I got work to do. Thanks.
Looks great. Few questions, was there a reason for going with new UCA's? Which setting/perch for the 6112's? How many inches of lift in the rear? Thanks...6112/5100s with OME 2885 rears and TC UCAs. Ride quality is amazing compared to stock. Gone is the nose dive, lean while cornering and overly soft bouncy ride. Highly suggest the 6112s if your on the fence about them.
Silly question from a Newb ... was it a pain installing with KDSS? Between this and maybe having a lean I'm a tad gunshy.
