Krayziekid
Hey guys, so I have a question for everyone running an auxiliary fuse block, specifically a blue seas box. I really want to add an extra fuse block in my 4Runner, partially to clean up the rats nest that is around my battery, but also to allow for easy expansion in the future. I kind of want to do this now while I only have a few accessories so I don’t have to spend days redoing wiring for a bunch of accessories.
I initially was going to do a bussmann relay box, and although it seems to be a good option, from what I have seen, I prefer the blue sea option as a distribution block.
So the plan right now seems to be the 12 slot fuse block with the cover and negative bus. I would run one 4Ga wire to a 100A circuit breaker, and then another 4Ga wire to the positive side of the block. I would then run a 4Ga wire from the negative bus to a ground on the chassis.
I just have two questions about wiring everything up before I jump in to this project. For small items like a CB, I will likely just run it to the block with a fuse to keep it simple. But for larger items (aux lights for the most part) I definitely want to run a simple relay. So these relays come after the fuse block (i.e. Battery -> Breaker -> Blue Sea Block -> Relay -> Accessory). I will run wire to pin 30 for power. I can then run the ground from pin 85 on the relay back to the ground bus on the fuse block right? Or is the ground bus on the fuse block meant for the ground coming from the accessory itself?
And then my other question is, is it possible to make the blue sea fuse block ignition switch without everything getting too complicated? I am normally very good about making sure everything is off before I turn off the car, but it would simply be some added insurance. Thanks for any advice!
