Blue sea switches: what’s the difference
thobry
Is there a difference in using a 300 amp M-series battery switch ($24 on amazon) vs a 100 amp 187 series circuit breaker switch ($52 on amazon)?
I see there’s a price difference but could I just use the M-series battery switch to disconnect my blue sea fuse box from the battery system in my 4Runner?
Thanks!
Thanks!
Sure you could use a switch as a disconnect, but the purpose of the circuit breaker is that it will trip if any piece of downstream work shorts out. It will prevent fires or damage.
Why not use a Maxi-fuse holder right off the battery? They come in 60, 80, not sure if 100 also, maybe. That will be cheap and still protect. Or put the maxi-fuse before the switch if you still want the on/off feature.
People go for the breaker as it is the neatest solution.
Edit: after looking at the 2 products, there is also the size factor. The switches are kind of big and bulky for under hood work. The blue seas breaker is smaller and neater.
youngrk
