BO010-01 9-12-07 Rust on tailgate
CJ3Flyr
Super Moderator
One more for tailgate staining/rust spot:
TSB BO010-01 9-12-07
It's not on the list but I have the pdf on my computer.
Technical Service
BULLETIN
September 12, 2007
Technical Service
BULLETIN
September 12, 2007
Title:
RUST ON BACK DOOR GARNISH
Models:
’06 – ’07 4Runner
BO010-07
Introduction
Some 2006 – 2007 model year 4Runner vehicles may develop rust around the back door
garnish. Follow the repair procedures described below to address this concern.
Applicable .
2006 – 2007 model year 4Runner vehicles produced BEFORE the Production
Vehicles
Change Effective VINs shown below.
Production
Change
Information
PLANT OPTION VDS PRODUCTION CHANGE EFFECTIVE VIN
TaharaTahara
w/ow/o
Back Monitor
ZU1#R JTEZU1#R270096214
BU1#R JTEBU1#R170125414
w/Back Monitor w/Back Monitor
ZU1#R JTEZU1#R270096242
BU1#R JTEBU1#R670125117
HinoHino
w/ow/o
Back Monitor
ZU1#R JTEZU1#RX78085897
BU1#R JTEBU1#RX78100593
ZT1#R JTEZT1#R578012029
BT1#R JTEBT1#R778041795
ZU1#R JTEZU1#R578087259
BU1#R JTEBU1#R578102361
ZT1#R JTEZT1#R278012098
BT1#R JTEBT1#R278042168
Parts
Information
MODEL
PREVIOUS PART
NUMBER
CURRENT PART
NUMBER
PART NAME QTY
w/o Back Monitor 76801–35460 76801–35461 Garnish Sub Assembly,
Back Door, Outside
1
w/Back Monitor 76801–35470 76801–35471 Garnish Sub Assembly,
Back Door, Outside
1
Warranty
Information
OP CODE DESCRIPTION TIME OFP T1 T2
BD7035BD7035 R & R Garnish Sub assembly Back Door R & R Garnish Sub–assembly, Back Door 040.4 76801 354#076801–354#0 6767 1717
Applicable Warranty*:
This repair is covered under the Toyota Comprehensive Warranty. This warranty is in
effect for 36 months or 36,000 miles, whichever occurs first, from the vehicle’s
in-service date.
BODY
* Warranty application is limited to correction of a problem based upon a customer’s specific complaint.
Toyota Supports ASE Certification
Page 1 of 3
RUST ON BACK DOOR GARNISH – BO010-07 September 12, 2007
Repair For additional information on replacing the back door garnish, refer to the Technical
Procedure
information System (TIS), 2006 or 2007 model year 4Runner Repair Manual, Vehicle
Exterior – Exterior Panels/Trim – “Exterior: Back Door Garnish: Removal”.
1. Remove back door garnish sub–assembly.
A. Remove the assist strap hole cover.
B. Remove the assist strap assembly RH.
C. Remove the back door trim panel.
D. Remove the service hole cover LH.
Assist Strap Hole Cover
Assist Strap Assembly RH
Back Door
Trim Board
Service Hole Cover LH
Back Door Trim Cover
Non–reusable Part
Page 2 of 3
RUST ON BACK DOOR – BO010-07 September 12, 2007
Repair 2. Remove back door service hole cover LH.
A. Remove the 6 nuts.
Procedure
(Continued)
B. Disengage the 2 clips by pulling the garnish, and remove the garnish.
3. Replace the back door outside garnish sub–assembly with:
Without the back monitor: P/N 76801–35461
With the back monitor: P/N 76801–35471
NOTE:
Due to the varying degree of stain that can develop, some vehicles may need to be
repainted (or stain will need to be cleaned).
Clip
Back Door Garnish
Sub–assembly Outside
4. Install the service hole cover LH.
5. Install back door trim panel.
6. Install assist strap assembly RH.
7. Install assist strap hole cover.
Page 3 of 3
Thank-you Barefoot!
allcarhistory
