Body lift help!
7104R
Hey all, just needed an opinion I just installed a 1 inch body lift from toytec on my 2016 sr5p and put on my front bumper cover without moving the bumper support up as suggested by other 5th gen owners with a body lift. I did notice I had to use a little more strength to get screws to line up but all screws and everything ended up lining up almost perfectly. My question is will this be safe? Would I be better off moving that bumper support up? I don't want my cover flying off on the highway. Thanks!
did you do the install yourself? could you provide instructions so i can see how easy/hard it is. im contemplating on a body lift too.
Yea I did do it my self with pneumatic tools and snap on and it still took me about 5 1/2 hours to complete. Maybe it's because it's my first body lift but it was pretty time consuming for only 8 mounts. I didn't get the chance to take any pictures but it's pretty straight forward, if you look under your 4r you'll see the body mount bushings just follow it to the top and remove what needs to access it.
you should be fine with moving it up one notch.
Moved up the bumper support bar
Moved up the bumper support bar and reinstalled 6 of the 8 screws instead of 4 as suggested, the extra 2 however are just sort of wedged on the edge of the bracket not in any of the holes and are just on there for my peace of mind.
