Body Lift Opinions needed.
Kowitz
Hey,
At the end of this week, I should be ordering a 4xinnovations front bumper(somebody backed into my stock front bumper, so why not upgrade?!) But I am in need of some opinions. My truck is basically stock right now, but with 265/75 tires. It is a 1999 highlander, so it has the factory "tall" springs.
I obviously don't need a body lift currently, but in your opinion, do you think it would be smart to go ahead and purchase and install a 1" or 2" body lift now, planning ahead for larger tires eventually?
The reason I ask, is because 4xinnovations offers the bumper made for no body lift, and also for 1 or 2" body lifts.
Again, just looking for some good advice!
Thanks!
-Brenton
How big of tire to you plan to go? Are you going for height or off road performance?
If you don't like the idea of trimming a bit, then a 1" would help with 33s. I would avoid the body lift if at all possible though. 1.5-2" body lift is almost necessary on 35s.
IMO 1" is needed if running 33's and plan on wheeling. It helps clear the up travel and won't cause bent front fenders.
I doubt I will ever do 35's, because I won't want to re gear. But maybe just a 1" will do, for ease of clearing 33's.
I don't plan on doing anything too crazy with this vehicle, but something that is all around good off road, camping, trails, etc.
I guess I'll probably order a 1" body lift.
And recommendations on brands, or does it not really matter? Also, does anyone make a bracket or is there a DIY or anything for fixing the gap on the rear bumper after the BL install.
I got my 2" body lift from [MENTION=14772]shootmymime[/MENTION] at Fat Pat's body lifts. He's a forum member.
You wont have a gap in the rear, only in the front the rear bumper is actually connected to the body. For the front bumper its is a simple fix, there is a detailed thread showing the install of a Toytec body lift kit and it shows exactly what to do:
http://www.toyota-4runner.org/3rd-gen-t4rs/168410-toytec-1-body-lift.html
Check out my body lifts.
Fatpatsbodylifts.com
This.
1" is great, 2" overkill for most people unless you have 35s.
Do you really want 35s? I don't.
Will do, thanks!
Oh awesome, thanks for the info! Luckily I am going to be getting a new front bumper, made for a 1" BL so, I won't have to worry about that either!
This.
35s look cool, but I don't think I will ever get them. I have no real use for them, and I don't feel like re gearing. 33s is probably the largest I will go.
Thanks for the advice everyone! I love a forum with good info and good people.
Get the 1" BL option for your bumper. I wish I would have, but during the time I got my front CBI and my rear 4xInnovations bumpers they didn't offer the BL option. I have a 1" gap now, it don't look bad but definitely not as clean.
Does a body lift significantly effect the center of gravity/handling of a 4runner?
What would be reasons to avoid one? I am toying with the idea of keeping my suspension lift closer to two inches and adding a 1-inch BL to clear 33's
Not really any negatives unless installed incorrectly. They can be unsafe when you dont use grade 8 bolts and washers which most kits have now. Also radiator brackets, shift linkage adjustments and steering rag joint spacers are needed on larger lifts.
Factory is grade 5 btw. Grade 5 is more than acceptable.
Didn't want to start a new thread, just looking for some last minute opinions!
I'm going to be ordering my 4xinnovations bumper tonight.
I'm 99% sure Im going to order it without any hoops, because I like the clean look.
But every now and then I see a truck with the grill hoop/stinger and it looks fantastic.(I don't like the headlight hoops) So, no grill hoop or get the grill hoop is the question.
I don't plan on doing anything too crazy with this truck, so no hoops is most likely what I will choose. Unless someone tells me some pros of getting the stinger.
A grill hoop is not a stinger. Stingers come to a tight radius and stick way out in front of the rig.
Grill hoops look good IMO. Stingers are thankfully a fad that's going away.
I just assumed they were the same thing, some more extreme than others, since 4xinnovations calls it both in their add.
AndiGarage
