bought 2" old man emu lift kit & came with no instructions
da_mon15
Hey.
I just bought 2" old man emu lift kit. And in all the boxes there's no instructions any were. I was online and could only find instructions for newer 4runners no 1st gen 4runners.
Has anyone have installed it or can help.?
For a first gen?
It's pretty straight forward at least with the rear.. Not sure if you have a solid axle or ifs?
Make sure you really grease the new bushings too
OME on 1st Gen
Just installed that kit myself & extreme novice at wrench turning.
Leaf springs are straight forward, did mine one side at a time. Make sure to re-check torque on u bolts after 100 miles or so, somewhere around 80 ft lbs is what I did.
I did the torsion bar up front, not the best choice. Had to order new Nuts and bolts due to stress and fatigue on the OEM parts, seemed to be common practice. Only got about 1" up front and just over 2.5" in the back. Removed shortest leaf spring and leveled out a lil closer but still not to my liking. Off to 4Crawler for a set of the 1.5" upper ball lift. Parts arrived but now awaiting new upper and lower ball joints since I'll already be tearing into the front end.
Overall easy and expect a day to do depending on any rusted bolts and such. PB Blaster the night before will help, but take your time, double and triple check.
AndiGarage
