Brake bleeding w/ABS w/o the SST tool? ...
Thanks Mike
I was going to do the rears. I even bought another set of heavy duty stands in anticipation. But the look fine. Likely will do at the next time the fronts are due. Meanwhile I'm wondering if I should flush the rear lines and calipers. I guess I will.
Do you have any more info on the details of tripping the system to bleed without the scan tool? I can't locate that in the 2007 FSM.
If there's no air introduced to the master cylinder portion, you should be okay with the pump & hold method. The main point its that you can get air trapped in the master cylinder assembly and you wouldn't be able to "pump & hold" to get that air out of the solenoid pack because you need to actuate the valves which requires the Scantool, there is a section in the FSM detailing how to get the system to trip and bleed without the scantool as well.
I've had no problem bleeding for two brake jobs without a SST. Just turn the ignition on, and have a helper push the pedal to activate the pump.
This method does work effectively? It seems like there are so many different ways to "properly" bleed the fronts in this thread I am getting confused. I did the 5th gen conversion and now have a much softer pedal. I also had my shop bleed them as well and it got a little better but not quite right. If I give them a quick pump and then go full on braking it feels as I think it should. I have bled brakes many times in older non-ABS trucks with no problem. What I understand is that you pump it to get the pressure out of the booster with the engine off then bleed as normal with just the ignition on? Is this right? Or should the ignition be off? I just seem to be finding so much conflicting info and I really hate my local dealer and also don't have he money to pay them. I can get a second person to help me out...
I don’t know the answer, but I’m glad you dug up this thread because I’m going to be doing my 5th gen conversion as soon as all the parts come in. I had no idea this vehicle needed a special method of bleeding! I bought speed bleeders, and thought. I was good to go.:ohwell:
Master cylinder / bleed brakes issue
I've been reading this thread and have tried many of the methods here to bleed my 03 4runner, v6. I'm starting to think I have a master cylinder problem. My booster pump is running when ignition is on and builds pressure and shuts off...all good. If I have someone press and hold brake pedal down I can bleed rear brakes no problem just from pressure from pump...all good. The fronts are another story. I replaced calipers, rotors, pads up front and had the brake lines open and dangling for a couple days as I was doing other work. Fluid res never dropped and I didn't have any brake fluid to speak of on the floor, so I didn't worry much about it. Note: I just bought this truck "as is" from a dealer and expected to have some issues. Vehicle was drivable and brakes felt a bit hard at the pedal and did not release very well. So I found both front calipers with half of the pistons seized, but had not destroyed rotors yet but I replaced anyway. I figured a quick bleed and we are good to go. I cannot get any fluid to the fronts, period. I even removed the line at the master and there is not a drop of fluid!! I'm beginning to think the front brakes never were working at all. Should there not be some fluid coming out of the master? what am I missing?
I hate to bring up this old topic again but wondering if anyone on this thread ever had success with the soft pedal and how they achieved it.
I'm working on getting my 4Runner back to sharing DD since my driving habits have plummeted and no reason for fancy new truck anymore.
Anyhow, I've bled brakes many times in my life. I've probably pumped a couple containers of fluid through my 4Runner so far. Still have a very soft pedal. As other have, if I give a little bump then it helps firm up the pedal and it still has power to stop. If I don't, it feels like I end up bottoming out the pedal (which I know is not a good thing to do anyway). It can still stop but way too soft for me, I wouldn't let my wife drive as it is now. I got a Foxwell scanner tool but instructions are terrible on that. I know that you shouldn't need a tool to bleed the brakes, I've tried that, many times, still no success.
Otherwise I'm going to shop take to a shop and see what they can do and hope that it isn't the MC or actuator.
When I bled my brakes I had the ignition on and let the brake boost load up. Once it goes quiet I would have someone pump and hold. Crack the bleeder on the front passenger side. Did this 6 times per side. As for the rears, they are so much easier. Press and hold the brake pedal and the electric pump will keep pushing the fluid out. So you just crack the bleeder and wait a second or two and close it it off. Check fluid in reservoir and do it again. After that I had nice firm brakes. Also I swapped out for 5th gen calipers for the front and rear. 5th gen front rotors. Idk if those contribute to the brake peddle feel. I doubt. Probably just needed a good bleeding since I never touched it for almost 10 years. LOL.
Thanks Chompster4runner
I've followed the service manual process over and over.
I have no idea why it hasn't worked. My only theory now is that somehow I left the fittings off long enough air got to the MC/Actuator or the MC/Actuator is starting to fail.
My question is whether others who have had the same thing happen (and they're seems to be a few) ever got this fixed.
Thanks,
A fresh new year bump to a timeless thread.
I've owned my 03 with the "small" brakes since 2011. I now have about 180k miles on the old gal and she has big heavy tires and wheels along with the body armor, bumper, and winch to lug around. Although she sits in the garage 80% of the time now, I figured it was time I rebuild the brakes as the front pads were giving an audible indication they were low and as far as I can tell, the fluid looked original.
I rebuilt all of my factory calipers, had the rotors turned, and picked up new pads before reassembling. During that time the reservoir stayed topped off and I plugged the lines as best as I could to prevent much air from making it into the system.
Having a 1999 Lexus GS it operates like our 4runners in terms of the electronic motor that pressurizes a reservoir. I never could get the pedal feel I wanted in my Lexus after a rebuild on the brakes earlier last year, so I took it to Lexus, and despite it being a hefty bill, the brakes felt better than they ever had since owning that car.
So - equipped with this experience and knowledge, I didn't bother with anymore than bleeding the calipers a bit for safety before dropping the 4Runner at Toyota to do the fluid flush and bleed process properly.
Upon getting the truck back, I didn't feel great about the feel of the pedal. It felt okay - probably similar to how it felt before I did the brake job, if even that good. Compared to my Lexus, the pedal feels like garbage. I drove around for probably 15 miles trying to see if the pedal feel would improve. It didn't. I've had some experience in the Lexus, (before I had the MC bled properly) after letting the car sit overnight, the pedal would feel better in the morning. Not the case with the 4Runner. In fact, I cannot get the front wheels to lock in a hard brake in a strait line (33" BFG tires). To me this is inadequate at best, and closer to dangerous. It feels to me that the pedal stroke is far too long before I get good contact between rotors and pads and I never feel a firmness I get with the Lexus. I called the dealer and spoke to the service advisor about it. He told me the procedure with the tool would have completely flushed the system and gotten the air out of the lines and brake master cylinder completely. And then said maybe it's something else in the brake system - frozen caliper, failing BMC, etc. None of it really adds up and I feel either there's still air in the system or (as difficult as it is to believe) the pedal is and will always be just this mushy.
A couple of observations:
I've driven a GX470 with stock sized tires - as I understand it these all came with the "large" brakes - and the brakes feel SOOOO much better and more powerful than mine. I've also spent a fair amount of seat time in an 07 FJ Cruiser - also, as I understand it, these came with the larger brakes - and 33" BFG tires. Like the GX, I was very surprised how much better those brakes felt than mine.
Is it that the small caliper / rotor brake systems just feel lousy compared to the larger ones? Based on science and physics, the larger brakes should only be more effective at resisting fade by absorbing more heat energy and should have no bearing on pedal feel, as it's the same master cylinder that's doing the work on the pistons that should be responsible for the "feel". I considered the 5th gen brake upgrade, but dismissed it due to the relatively minimal difference I'd expect in performance.
I've noticed, as others have stated, following the engagement of the ABS the brake pedal will get firmness and the stroke will be reduced. I'm not sure why this happens exactly, but for a period of time (maybe minutes, maybe the remainder of the drive) the pedal feels great - like I wish it did all the time. I'm trying to rationalize what is happening. Obviously the solenoid(s) for the ABS system is actuating. Is an air pocket being released resulting in the better pedal feel and brake performance? And if so, where is it going? It seems based on my experience that a day later - after the car sits for a spell, this improved pedal feel vanishes, and the old mushy feel is back. If it's going into the lines, maybe doing a line bleed / flush directly after would be good? Would engaging ATRAC actuate the same solenoid(s)? Curious - as winter weather is here - maybe after a little skiff of snow, would it be worth getting out and engaging ATRAC and / or ABS, and then pulling back to the garage and trying to bleed out any air that escaped the master cylinder via the calipers before it runs back up to its nest?
Here's a video of the BMC firing up with the key on after sitting in my garage 2+ days. I'm a little surprised at how high the fluid rises in the reservoir when not pressurized. In the back of my mind I wonder if air voids are what are getting compressed as the fluid draws down. Curious if others have a similar occurrence - honestly I never really noticed before.
2003 4Runner Master Cylinder - YouTube
All this to say, I suppose I'll ask my spouse to help, and do some bleeding from each caliper, but I still am trying to find a solution for triggering the solenoid in an attempt to purge it of any air pockets that may have formed over time and somehow not gotten flushed with the dealers' service.
My turn
I have 5th gen brakes sitting in the garage. I will report back with what I do and whether it works or not.
Done:
Everything pretty much went according to plan but I did notice that after I had finished installing the first 3 calipers the master cylinder had almost completely drained. I had the front right caliper off for less than an hour so it makes me wonder about air in the master/ABS system especially for those of you who had the system apart for weeks waiting for parts. I was paranoid about it so I took it to a brake shop and told them to bleed it as though there might be air in the master cylinder. The pedal feel is slightly softer than I remember but I don't find that it gets any harder with multiple pumps and the truck is stopping just fine. The theory in my head is that we are feeding bigger brake pistons with the same master cylinder and that might account for that difference.
Now I just hope my new brake lines are actually extended enough for my upcoming lift.
A little more feedback after a few thousand miles. The 5th gen rear rotors are a pain in the butt. The center hole doesnt fit right and getting them properly centered requires a 2nd person to stand on the brakes or other creative solutions other wise the parking brakes catch and chaos insues.
Quick Bleed of Actuator on 99 4Runner
I know this is an old thread but I found lots of good info here, and I wanted to add in some info from my recent experience. Technically this should go over somewhere in the 3rd Gen tree but it also could be applicable here to some extent.
I too had the sinking brake pedal problem and ended up replacing the MC with an O'Riley aftermarket unit but no change. I finally took it to a very reputable independent shop who claimed the MC I just put in was not good. I questioned this as I've had good luck with aftermarket stuff but I let them put in a new O-fish-E-All Toyota one and that fixed the problem. So point to note is his comment that the aftermarket brake parts seem to not be very good. Other ones like clutch kit or such are just fine, but brake stuff seems to fail a lot.
Last of all I asked him, as an independent w/o any special SST and with a 3rd gen runner w/o the OBDII plug in for brake bleeding with a scan tool, how was he bleeding the ABS actuator? Easy peasy. They just turn on the key to pressure the actuator, wrap the actuator in rags and then break loose each hose connection on the top one by one and slowly let any air come out. Done. Of course they still do the manual bleed at the wheels after.
does anybody have an idea of how to find out the specs on the stupid nuts that hold the assembly in place? i managed to get three on and then dropped the 4th, think it went down into the covering of the steering column. tried to use magnets to get it, no luck. tried to get my 4yr old daughters hand in there, no go. was just going to go to ace hardware and get a replacement but i cant find any info on the threads and size. toyota says its 90179-08057 in the parts diagram, but apparently that was discontinued and replaced with 90080-17211. but neither of them say anything about size, thread pitch, etc. id really prefer not to have to go to toyota for a stupid nut since the hardware store is around the corner, but cant seem to figure out how to get the specs on this stupid nut. anybody have some info?
Your post doesn’t say what part with 4 nuts you are referring to. Take a nut that you didn’t drop with you to the hardware store and match it up.
AlaskaRuss
