Brake Booster Replacement
duffguy808
I have a few questions:
I am planning to replace my brake booster as it is faulty and leaking. The master brake cylinder sits in front of the brake booster unit which causes some interferences.
Do I need to fully remove the master cylinder and break the hard hydraulic piping or can I just move the master cylinder out of the way? Is it a good idea to replace both the brake booster and master cylinder at the same time like the timing belt and water pump combo?
I am trying to avoid bleeding the brake line a much as possible.
Thanks in advance
tuṣṭāva
