hi all, last weekend i tried replacing the brake pads on my '03 4runner and unbolted the two top bolts on the front driver side caliper and brake fluid started oozing out from between them. immediately i put the bolts back in and tightened it back.
i thought i had to remove all the four bolts to get to the brake pads but a search on the forums showed me that, i can just remove one metal clip and two retaining pins to remove the brake pads, but this didn't work. i could remove all the three clips/pins but the thin metal rod wouldnt budge out even after i compressed the pistons inside using a c-clamp.
please let me know if did anythign wrong. this happened last week and i've been regularly checking the brake fuild level and it remains the same as of now, and if someone had actually removed the four bolts on the calipers and not have brake fluid ooze out. i did change brakes on three cars before - a mazda, an acura and a bmw 740 before, so its not like i'm new to this.
thank you
minghi
thank you
minghi
