Brake pad brand recommendations
Jtwo said:
Would you guys use slotted rotors or OEM?
I am getting ready to service my brakes and have been searching for slotted rotors for a good price. If you know of a place please point me in the right direction.
Cheers,
-J
this brought up the rotor topic. so yes, it is related and people will be able to read the post and make a wiser decision to fit there needs.
gapboi210 said:
hey OUA the whole point of a thread is for people to try and help each toher by putting what knowledge they have aof a topic and let the erpson decide for themselves. So wah. cry about it.
Yes - on helping each other regarding the topic..
What does slotted/drilled rotor have to do with type of brakes???
:bash:
Any type of brake pad (ceramic, organic, semi-metallic) can be used on any type of rotor (slotted, drilled, solid, vented).
I replaced my mom's front pads today (97 4Runner limited) with OEM which stopped the rubbing/wear sound I was hearing. I also purchased OEM shoes for the back but I have no experience working with drums. Is there a good DIY you can point me to and any special tools I would need?
(Yes I did a search. Found a pretty good explanation for the pads but nothing about the shoes.)
quote:
Originally posted by el_chapu-bling
I am replacing the brake pads on my '00 V6 2WD and I just wanted to get an idea what everyone here recommends as far as brands and where to buy them (best prices, etc.) and which brands I should stay away from.
Also, is there a clear advantage (that is worth paying more for) to using ceramic over semi-metallic?
Thanks in advance.
Just as a FYI, Autozone has semi-metallic pads ranging from $14.99 to $45.99, and ceramic from $37.99 to $99.99.
Just out of curiosity how many miles are on your 4runner?
If you hate brake dust and brake noise
go ceramic.
If you want to save $$$
go semi-metallic.
If you love brake dust
go organic
As for stopping distance - they are all about the same.. As I recall semi-metallic has the best stop power only winning by a few inches shorter.
so which rotors do you guys recommend?? My stock ones are warped and vibrate, Im gonna get the Carquest Gold Ceramics... just curious as to which rotors to get.??
No help on the shoes?
Jhunt
