Brake pedal slowly goes to the floor
KD5NRH
Member
Swapped in a rebuilt MC, bled the heck out of everything, and it's still doing it. Brakes have always felt like they needed too much force, but I figured that was just crappy design. I can definitely feel the difference between engine off and engine on, so the booster is doing something, but even with the engine off, if I sit holding the pedal, it will go to the floor over 15-20 seconds. With the engine on and in gear, it's losing hold as it sinks, so sitting at a red light requires pressing harder until it just can't hold anymore and I had to use the parking brake to keep from rolling through the light.
I parked it on clean concrete, held the pedal until it was all the way down at least a dozen times, and no fluid visible anywhere. MC reservoir still full too.
Couldn't find a MC rebuild kit for it, but I went ahead and popped the C clip off the old one, pulled the pistons, and everything looks pristine: it's about two years old, (trying to fix the above mentioned needing more force and having more pedal play than pretty much everything else with modern brakes) and I see no wear or scoring on the walls, and even with some magnification, the seals look brand new.
Any thoughts on what would do this other than leaking MC seals?
Brake pedal sinking to the floor with no external visible leaks is the master cylinder, no matter what. Internal leaks like you are experiencing is the 'normal' failure mode.
This is for the '96-'00 4Runners:
It is very important you follow the bleeding procedure when you put in a new MC - if not followed correctly, the pedal will feel wrong and the rear brakes won't work correctly. If you got any air in the ABS module, bleeding that is a separate hassle, since there is no easy way to bleed the ABS actuator with a scan tool. You must get the bleeding 'good enough' to go for a drive and get ABS to activate on a loose surface.
Get a new OEM master cylinder. I would probably also trust Advics or Centric (available on RockAuto).
I would suspect the booster issue is separate. Maybe a mostly-clogged check valve or similar...
-Charlie
-Charlie
^^^^ What he said.
Be sure to bench bleed the new MC first, then bleed all 4 wheels in the order specified in the FSM, don't forget the LSPV if you have one.
Bleed several times.
As for the ABS system, one trick I've found that works on some vehicles is to thoroughly bleed the system with engine off, then running, and again with engine off.
Clamp off all your brake hoses with needle nosed vice grips and see if the pedal still goes to the floor. If it doesn't, master cylinder is fine, if it does the problem is at or near the wheels. Toyota trucks are notorious for having excessive brake travel if the rear brakes are way out of adjustment or the calipers have one or more stuck pistons. Did you take your drums off and check the wheel cylinders? Sometimes forcing a few ABS activations on grass or loose dirt can help a soft brake pedal on a Toyota.
My breaks do a simaler thing, but they are just super spongy, but when i pump them they firm up. is this related to not havingh my booster conected, my abs also still works, but the light will itermitently come on and it will stop working
No, that's not similar. You have air in the system somewhere. Assuming you have a '96-'00, follow the bleed procedure above and then make sure you bleed the abs system (basically, get ABS to engage and re-bleed after).
-Charlie
Jyb
