brake upgrade options??
T?@\7
I've heard if other yotas doing the tundra brake upgrade, is that an option for us 1st genners?? If yes, what are the details? And if not, what's the best option?
thanks
Not sure on the t100, but another common one is just to upgrade to to 2nd gen v6 stuff. The calipers, master, and booster are all bigger and 100% bolt on.
Any upgrades for a 2nd Gen v6?
If I can fit some tundras ima keep it ifs if not ill stick with my stocks and sas my truck
No. Tunda stuff will work on a 3rd gen, but the biggest you can go on a 2nd gen is T100 stuff. Although with the right amount of money almost anything is possible.
thanks
Other than converting the rear to disks, your only option is replacing your front calipers with larger ones from a later V6 truck. You may have some wheel fitment issues, but you can grind down the fins on the caliper with no problems.
ghengiskhan
