Brand new owner with a few simple questions
shomann
First, thanks to the forum! I have been lurking here in anticipation of moving in the T4R community by end of summer, but found a deal I found impossible to pass up yesterday:
(There will be more pics to come, and I have certain...plans ;) )
It's a 2006 V6 Limited in Shadow Mica. I was actually shopping for a Sport Edition, but the price, 1 owner status, and being Toyota Certified sealed the deal. I traded in a 2002 Lexus GS 430 for it, so I am not a complete noob about Toyotas :)
First question:
Where would I be able to find a OEM coin holder? It seems like a simple thing, but I really would love to have a dedicated holder. It seems to be the ONLY thing missing from this truck ;)
Second:
On the Lexus, we had a table of electronic settings for all the little things like door locking, alarm, etc called C-Best. I know the 4-Runner has something similar, but is there a handy table floating around out there I can refer to?
That was quick! Thanks Dawg!
Moderate lift/leveling. Better AT tires. Not sure if I want to swap the 18"ers out - I actually like the look quite a bit. Definite stereo and multimedia upgrade. Possible cargo rack with lighting that's one-plug removeable. Definite HID retrofit.
I know I will sacrifice mileage for some of this, the trick is, I don't want it to suffer much (and I may be deluding myself).
Once you get the coin holder figured out start the mods. You are on the right track with what you are thinking. I highly suggest a Magnaflow Cat Back exhaust system. I get turned heads whenever I push the throttle!
Not sure what you mean by the electronics.
Welcome to 4Runner ownership and modding heaven.
Nice to see you getting active on this board Dave. :bigok:
You know, like being able to set the door locking states, the way the keyfob works when you push the keys on it, etc.
For instance, the default state when press the lock key is for the car to freak out and whine at you until you close the door. Once you do that, the car stays UNLOCKED. I would much prefer a long tone that stops, then once you close the door, the car locks itself. (My Subaru Legacy was this way and while it may be easier to lock the keys in the car, it is far more intuitive)
Here is the C-Best table for the 2nd Generation Lexus GS 300/430:
Code:
Category            Item Select             Default     Description        Options
Wireless Door Lock  OPEN DOOR WARNING       ON          ON/OFF of 10 second buzzer if door is open when locking with wireless transmitter           ON/OFF
Wireless Door Lock  WIRELESS BUZZ VOLUME    MID2        Adjusts the volume of the wireless buzzer                                                   OFF/MIN/MID1/MID2/MID3/MAX
Wireless Door Lock  WIRELESS OPERATION      ON          ON/OFF of the wireless door lock function                                                   ON/OFF
Wireless Door Lock  CAR FINDER              ON          ON/OFF of the car finder function which lights up all turn signal lights once when lock
                                                        button is pressed on transmitter while vehicle doors are locked and dosed                   ON/OFF
Wireless Door Lock  ALARM FUNCTION          ON          ON/OFF of panic function if transmitter button is pressed for 1.5 seconds                   ON/OFF
Wireless Door Lock  INT/LGT ON/UNLOCK       ON          ON/OFF of interior lights when vehicle is unlocked with transmitter                         ON/OFF
Wireless Door Lock  UNLOCK/20PER            ON          ON Pressing transmitter unlock button once will unlock drivers door pressing
                                                            twice will unlock all doors
                                                        OFF Pressing transmitter button once makes all doors unlock.                                ON/OFF
Wireless Door Lock  TRUNK LID OPER          0.8PR       OFF     Transmitter will not open trunk
                                                        0.8PR   Trunk button must be pressed for 0.8 seconds-to open trunk 1
                                                        1TIME   Trunk button must be pressed once to open trunk
                                                        2TIME   Trunk button must be pressed twice to open trunk                                    OFF/0.8PR/1TIME/2TIME
Wireless Door Lock  AUTO LOCK DELAY         30S         After the vehicle is unlocked with the transmitter vehicle will lock if a door is
                                                        not opened before the specified time (30 or 60 seconds)                                     30S/60S
Door Lock           UNLOCK/PARK             OFF         ON/OFF  of door auto unlock when vehicle is stopped and shifted into Park                   ON/OFF
Door Lock           ALL UNLOCK/OPN-CL       OFF         ON/OFF  of door auto unlock for all doors when drivers door opens within 10 seconds
                                                        of turning the ignition key from ON to OFF                                                  ON/OFF
Door Lock           UNLOCK/KEY TWICE        ON          ON When unlocking the drivers door one turn of the key will unlock drivers
                                                        door only two turns will unlock all doors
                                                        OFF When unlocking drivers door one turn will unlock all doors                              ON/OFF
Door Lock           ANSWER BACK             HAZARD      HAZARD: Hazard lights will blink once when transmitter is used to lock vehicle
        and twice when unlocking the vehicle providing the doors hood and trunk are dosed.
                                                        OFF: Hazard lights will not blink                                                           HAZARD/OFF
Security            PASSIVE MODE            OFF         ON/OFF  of automatic activation of the security system 30 seconds after key is
                                                        removed from ignition and doors are dosed. Upon reentry driver has 15 seconds
                                                        to:
                                                            1) insert key into the ignition front door or trunk
                                                            2) use transmitter to open vehicle                                                      ON/OFF
Security            UP/DOOR KEY             ON          ON/OFF: Windows will roll up when key is locking drivers door and
        held for 1.5 seconds with the ignition off                                          ON/OFF
Power Window        DOWN/DOOR KEY           ON          ON/OFF: Windows will roll down when key is unlocking drivers door and
Power Window        DOWN/WIRELESS           ON          ON/OFF: Windows will roll down when transmitter unlock button is held
Wiper(LS400)        REWIPE FUNCTION         ON          ON/OFF  of delayed rewipe of windshield 15-30 seconds after washer is used                  ON/OFF
Wiper(LS400)        SPEED MODE              ON          ON/OFF  of intermittent wiper speed change as vehicle comes
        to a stop with the wipers set on LOW                                                ON/OFF
Illuminated Entry   LIGHTING TIME           15S         Delay of interior light dimming function.
                                                        Interior lights will dim quickly if ignition is ON                                          7.5S/15S/30S
Illuminated Entry   I/L ON /UNLOCK          ON          ON/OFF  of interior light up when unlocking door using door lock cylinder.
                                                        Regardless of this setting interior lights will still light up when interior
                                                        light switch is in the door position and door is opened.                                    ON/OFF
Warning             LIGHT REMIND            OFF         ON/OFF  of headlight reminder buzzer                                                        ON/OFF
Warning             KEY REMIND SOUND        NORMAL      Frequency of key reminder buzzer                                                            LOW/NORMAL/HIGH
Warning             KEY REMIND VOLUME       LARGE       Volume of key reminder buzzer                                                               SMALL/MEDIUM/LARGE
Warning             LIGHT OFF DELAY         30S         Delay time for headlight turnoff to specified setting                                       OFF/30S/60S/90S
Warning             LIGHT CTRL TYPE         CURRENT     OLD    : 6 second automatic headlight ON delay 8 second headlight OFF delay
                                                        CURRENT: 15 second delay for automatic headlight ON or OFF                                  CURRENT/OLD
Light Control       SENSITIVITY             NORMAL      Adjusts the sensitivity of the automatic headlight illumination system                      DARK2/DARK1/NORMAL/LIGHT1/LIGHT2
Light Control       DISP EX ON SEN          NORMAL      Adjusts the brightness of indicator lights (Shift Taillight Headlight Cruise
                                                        and Power Mode indicators) when headlights are ON                                           DARK2/DARK1/NORMAL/LIGHT1/LIGHT2
Light Control       DISP EX OFF SEN         NORMAL      Adjusts the brightness of indicator lights (Shift Taillight Headlight Cruise
                                                        and Power Mode indicators) when headlights are OFF                                          DARK2/DARK1/NORMAL/LIGHT1/LIGHT2
Tilt & Telescope    AUTO TILT AWAY          ON          ON/OFF  of auto away/return function                                                        ON/OFF
Sliding Roof        OPEN/DOOR KEY           ON          Links sliding roof to DOWN/DOOR KEY function when door is unlocked for 1.5 seconds          ON/OFF
Sliding Roof        CLOSE/DOOR KEY          ON          Links sliding roof to UP/DOOR KEY function when door is locked for 1.5 seconds              ON/OFF
Sliding Roof        OPEN/WIRELESS           ON          Links sliding roof to DOWN/WIRELESS function when transmitter unlock
                                                        button is pressed tor 1.5 seconds                                                           ON/OFF
Sliding Roof        DOOR KEYOPER            SLIDE       Changes operation of sliding roof when using key to open or dose roof                       SLIDE/TILT
Sliding Roof        WIRELESS OPER           SLIDE       Changes operation of sliding roof when using transmitter to open roof                       SLIDE/TILT
Air Conditioner     AIR INLET MODE          AUTO        AUTO  : Will automatically change air inlet to RECIRCULATE when A/C is turned ON
                                                        MANUAL: Will not change air inlet when A/C is turned ON                                     AUTO/MANUAL
Air Conditioner     COMPRESSOR MODE         AUTO        AUTO  : Will automatically turn ON A/C if AUTO button is pressed when blower is ON
                                                        MANUAL: Driver must turn ON the A/C when Auto button is pressed                             AUTO/MANUAL
Air Conditioner     COMPRS/DEF OPER         LINK        Link  : A/C will turn ON when Defroster is ON
                                                        NORMAL: A/C must be manually activated when Defroster is turned ON                          LINK/NORMAL
Air Conditioner     AIR INLET OPER          LINK        Link:   In the event of A/C malfunction air inlet will change to OUTSIDE.
                                            NORMAL:     Air inlet will not change.        LINK/NORMAL
Even for a 6cyl? The last car I drove had the V8 you now use (although the displacement was lower, the power was higher ;) ). Yes, that would sound epic, but I didn't want the V8 this time around :)
