BrianSD_42 Photo Journal Build Maintenance Thread
Installed 2nd Layer of Soundproofing Material in all 4 Doors
The foam is sticky on one side so its easy to install. The part that takes forever is cutting each piece to fit into the door crevices. I ended up bringing the panels inside and doing most of the cutting in my living room. 4 hours later all doors were done.
Pictures .....
Notice the 6x9s installed into my rear door!
:humble:
Is that ensolite foam? I would be curious to know the effects. I was planning on doing the same thing when the cold winter months are done here in WI. Planning on putting it on all my interior plastic panels.
Yes it is ensolite foam @ $20 yard. I bought 2 yards and it was enough for all 4 doors.
It is a bit quieter than before although I haven't driven on the freeway yet.
Here are my new post body lift measurements :)
This is without sliders and no front skid plate installed.
Sonoran Steel 1.2A Lift (w/ extra notch) + 1" BL
Front 39 & 5/8"
Rear 41 & 1/4"
:bat:
The ride is mostly the same. The poly body mounts are a slight bit stiffer but the BL does not change the suspension so no real change there.
Is that Superstition?
[MENTION=47731]TheeMikeB[/MENTION]
I don't think so. Its a sand dune in Death Valley.
Btw your avatar is great.
Oh, when you said Anza Borrego I thought that was it. I'm from SD and was a big desert/river rat, it's been YEARS since I was at superstition and for a second I thought this was it.
I love this Avitar too... thanks.
Had new Inner & Outer Tie Rods put in. Toyota of course.
$129 x 2
$49 x 2
Results .... WOW .. WOW.
Keep in mind I'm at 220k+ miles and these were the originals. Pretty much everything else has been replaced.
In other news ...
Tomorrow I will be putting my front sway bar back on. I recently removed it due to squeeking OEM frame mount bushings. The paint had worn away and the bar was rusting onto the bushing all causing horrible squeak.
One interesting thing: as soon as I removed it my 285s started rubbing against the stock UCAs on any decent turns. This never happened with the sway bar on. It makes a difference!
:party:
******* 02-14-14 | LED Floodlight Pictures *******
My truck can power its own floodlight for hours and hours and hours now.
So I was at Costco the other day and they had this cool looking SnapOn LED Powered Floodlight for only $25-ish. It only requires 30W to run. Just 30W !!!!!
Here it is powered by my 175W Pocket Sized 12V to 120V Inverter.
:hunter:
******* 02-14-14 New Stereo Installed *******
Wow. I just installed a new stereo, details below, and it is awesome. Particularly the bluetooth audio which actually sounds surprisingly great.
Pictures - Alpine CDE-HD149BT Stereo Installed
This one:
Alpine Electronics of America, Inc.
I paid $230 on EBAY for a brand new one with 1 year warranty.
*4V Pre-outs (x6)
* No tilt :(
* Decent screen
* HD Radio Tuning Built In (sounds great!)
* High Quality (2013 version) BlueTooth Audio
The BlueTooth audio really surprised me because I thought it would sound like crap. This newer equipment when paired with a new Android Device like my Nexus 7 (v2) is awesome. The head unit knows the song and you can still control everything from the Android Device which I have mounted over the clock.
Pictures of the install. I am of course using a 4 channel amplified so I have no need for the stereo wires - just cap those off. I used spades to connect the various power and antenna wires. I don't prefer to solder the wires because it is unnecessary and makes changing the stereo a pain.
Lastly - I updated my original stereo install post to include all details and updates. You can find it here ---->
Direct Link to Post 767748
http://www.toyota-4runner.org/3rd-g...rnal-build-maintenance-thread.html#post767748
:bat:
02-14-14 | Finally! Pictures of my Body Lift Installed & Flares & newly modded Sliders
You can also see it installed with the full lift in the night picture a few posts above.
I finished the body lift a few weeks ago but haven't really posted that many pictures. Here are a few with more to come after this weekends trip.
:bat:
Looks good, if you really want to offset that black you should pain your bumper pink and put I love boobies all over it. You know, for breast cancer.
No such thing as tooooo black. I don't think your truck is black enough, like the limited badges on the side. Haha. But those wheels would look great.
delislerebecca
