BrutalGuyRacing's Build Thread
I don't know if you got back to your front end Scott. I just did my LCAs in the driveway. I cheated a bit and bought complete units from Raybestos. Popped right in, but the grease fitting on the ball joint is tough to get to past the CV.
I only had one frozen bolt, the right, rear. My suggestion is a 4 1/2" angle grinder with a metal cutting blade. Put it between the washer and the bushing. Won't mess up the frame bracket and cuts pretty easy. I only had a 4" grinder, which would not quite go all the way through, had to finish up with the Sawzall.
The greaseable bolts worked great. The only issue is getting the front ones in past the axle shaft. You just have to slide the sleeve in from the front about half way, then slide the bolt and washer through from the back. Easy-Peasy.
Off for a much needed alignment. Got some wonky camber going on now. Looks like a NASCAR short tracker.
woot just saw this
i forgot i had a build thread lol
no i haven't done much but use the truck lately.....
Well im done for the weekend and maybe the year for working on my truck
Did front and rear brakes, inner + outer tre's, uca, lca, alingment cams, cv's, shocks,springs, tire swingout, wired my new license plate light and ran wiring for new backup camera and reverse lights, painted underside of truck, greased everything
Next up
Sliders
Skids
Mount air comp " going to be a pain"
Mount tank and plumb it
Boot slide mod
Double water can holder
Add flag mount
Finish reverse camera
Install gorilla tires
Beat / cut everything to fit gorilla tires
Then a was and wax and interior detail
What a weekend
BE careful with those Alignment cam bolts. It is real easy to strip out the hole on the cams so the bolt spins without the cams. The nice folk at Firestone fouled up two of mine while flattening two of the cam tabs.
What with the new moog greasable cams?
Juat had my alignment done today
Updates
Threw these tc uca's on
Pit there rotors all around
And new front calipers and pads as well
Painted the roof racks
Gutted my xreas and entire front end
Replaced lca's, bj's, tre's,cv's,kings up front and icon overland and 2.0 out back
Some skyjacker ext sway bar links
Installed front hidden hitch
Some new greasable alignment cams
Yep It is real easy to round out the D shaped holes.
that's shocking
i thought it would be hard to strip them out.....
well hard compared to the factory ones
good to know
did you have to buy replacements? or did you tack weld them back>?
i just pretty much finished up all my front end and rear end .....
all i got left now are the fun mods
sliders,skids,oba,obw,ect
f them little yellow lights in the bumper
if i can buy 06 and have the blinker where it should be id be happy
what do i need to swap them in?
You can get clear lenses amber bulb turn signals as well, its just a cutout in the bumper they push into on the CBI's. I went with the clear lenses instead of the yellow ones.
Its more of i hate the running
I am going to try and eliminate them and just make a blinker in the headlight
Or just make the blinkers blink and not stay on all the time
Which replacement front calipers did you get? I need to do mine very soon.
I picked up what ever advanced auto had in stock
I am out of town for the weekend
But when i get back i will check for you
IDK what you have against running lights, but the blinker/drl has 3 wires - 1 hot, 1 ground for blinker and 1 ground for DRL. DOn't connect the DRL one.
Ty
Will look into it
Around here lights suck
Ruins the fishing
Ruins all night vision
**** lights
I just removed the bulbs un the pocket door or puddle lights
Now when i open a door no lights happen
Makes me happy
Now next week i need to cut wire 15 to kill the key in ign chime
Then all i have left are the stupid running lights
Nothing like starting the car in the woods or beach and lighting up the whole ****ing place
Ty
Will look into it
Ruins the fishing
**** lights
Makes me happy
Didn't realize we could get rid of that stupid ignition chime! Thanks for posting that, I looked it up and am going to do that today! I HATE that thing!!!! Ugh
that's shocking
good to know
I will need replacements. Will probably get the Toyota units this time.
HAd to weld the cam tabs back where they should be on one side.
Dam
This was in no fault due to the moog cams correct?
Just alignment shop error.
Not the same guy that did not tighten the cams at that rausch trip was it
Dam
Same shop, don't know if it was the same tech. The Moog cams are a bit wek by design compared to the Toyota units. The tech just needs to be ginger with them. I cannot imagine why he needed to muscle mine. Brand new LCA's with well lubed adjusters. Should have moved around pretty easy.
Yea
Might be time to change shops
Lol
Just had mine aligned after i replaced them and the front end
They moved like butter
Time will tell
CoaterZ_FL
