BrutalGuyRacing's Build Thread
New mod today
Just missed the radiator
Was parked
Got into car backed up a few feet cut to turn right pit in drive crunch
The best part is the second pole hit the same exact spot on the running boards as my last incident
Err so much for keeping that bumper
Update
Got a few more pieces to the puzzel
Also got most things mounted on my roof rack
Installed the sunroof windjammer thingy
And some window vents
All loaded up for the weekend
Did a little trading of my old tacoma parts for some runner parts
Got 19.5 mpg fully loaded
Also picked this up
Its huge
And got a set of these
All ss hardware
Checked all my window seals and all is dry
Picked up these
Tbc
Update
Also picked this up
Its huge
All ss hardware
Picked up these
Tbc
Where'd you find the rotors? How much?
Looking good! Loving everything so far man. :cool:
Total thread jack but i'm scrolling through and I can't handle this.
You just quoted 15 pictures immediately after he posted them to ask about one item...
Come on man.......
:redbrick:
Come on man.......
:redbrick:
LOL, I was thinking exactly that as I was scrolling down the page.
SO UM YEA
ALL PACKED UP, PARTS READY AND THE GUY WITH THE SHOP TEXTS ME.
HE IS SICK WITH FEVER
ERRRR
so few questions
with aftermarket front bumper - wtf do you do with our blinkers?
can i put the blinkers into headlight....
Yes and no. Yes, you can have blinkers, no you can't put new ones into the headlight with out major mods. But you can rewire the current parking lights to blink off then on.
SO UM YEA
ERRRR
so few questions
You don't have all those parts on yet? Hahaha. That's crappy luck man. Hope you can still get it done.
As for the blinkers...you can upgrade to 06+ headlights since they have blinkers in them.
SO UM YEA
ERRRR
so few questions
check out the little orange blinker in the bumper too. I'm gonna do those with my halos as blinkers. But 06+ is a good move if you don't want to do a retrofit.
f them little yellow lights in the bumper
if i can buy 06 and have the blinker where it should be id be happy
what do i need to swap them in?
Filler panels and wiring harness, each is $28/side. So $120+ S&H. Then either H11 harness and H11 bulb or an H11 HID kit (the ballast will plug right into the factory 9006 connector). Both are about the same price if you get a cheap HID kit.
I was patient and picked up my used OEM headlights separately on eBay for $55 and $65, but if you don't plan to do the black headlight mod you can get some Depo or other brand ones for about $160. Not sure if the projectors are as good, haven't seen any reviews.
I think someone recently had some luck rewiring the parking light to be the blinker on an 03-05 model.
I don't know if you got back to your front end Scott. I just did my LCAs in the driveway. I cheated a bit and bought complete units from Raybestos. Popped right in, but the grease fitting on the ball joint is tough to get to past the CV.
I only had one frozen bolt, the right, rear. My suggestion is a 4 1/2" angle grinder with a metal cutting blade. Put it between the washer and the bushing. Won't mess up the frame bracket and cuts pretty easy. I only had a 4" grinder, which would not quite go all the way through, had to finish up with the Sawzall.
The greaseable bolts worked great. The only issue is getting the front ones in past the axle shaft. You just have to slide the sleeve in from the front about half way, then slide the bolt and washer through from the back. Easy-Peasy.
Off for a much needed alignment. Got some wonky camber going on now. Looks like a NASCAR short tracker.
Ambrose67
