Question about the bug deflectors. How to they mount? Is it in an inconspicuous place? One of the reasons I never got one was I thought they had mounts that wore into the painted surface. I've seen this on other vehicles.
Wraps around the lip of the hood and plastic screws or clips hold it in place from the underside of the hood lip.
Typically, over time the rubber nubs that are supposed to prevent the deflector from scratching your hood will actually be the cause of wear marks.
Also, if you happen to park your rig under a tree or in a wooded area, pine needles and twigs and leaves sometimes end up lodged in there and accumulate over time if you don't periodically remove the deflector to clean it it out. Unchecked, that can eventually accelerate the deterioration of the hood.
My T4R came with the original OEM one when I bought ity from the previous owner. It had a small crack on one edge, so I chose to remove it. I was gonna repair it, paint it and put it back on, but aside froma few spots where the deflector damaged the paint on the hood, the hood itself was in decent enough shape that I didn't feel the need to re-install the deflector. I got used to the look without it (you can still see it in my current avatar).
I'm really neither for, nor against the bug deflector on a T4R. I think it looks good with or without. I feel like the pros of having one don't outweigh the cons and vice versa without.
I think I've had a bug deflector on half the cars I've owned and ever single one of them scratched and damaged the hood over time. So you either have to live with the damage from having the deflector or live with the damaged caused by not having one. 6 of one, half a dozen of the other, really.
