Bushings
Fizban
Currently half of the bushings on my car are wrecked, so i was wondering if any of you guys have changed all of the bushings in your car and if you had the part numbers to order them since its quite expensive in my country to change them all.
Year matters for a couple of those answers. What bushings do you want to replace?
In my 96 I've so far replaced the front lower control arm bushings with oem, rack and pinion, sway bar link and both sway bar bushings with poly aftermarket, rear upper control arms (whole arms, new oem, bushings are captive), and rear lower control arms with low mileage '02 junkyard arms because the bushings in the 96's are captive and the bushings in the '02's are apparently replaceable when it comes time. That's all the ones I can remember for now.
