Titanpat57
Senior Member
I think before you go on the attack you should completely think your comment through. You have absolutely NO control in an emergency situation. Trailer brakes won't save you in wind gusts or if you are cut off/run off the road and start spinning/tumbling. Situational awareness is the only thing you have control over. Reading other posts you will see that is the common point people are bringing up. Read the road ahead, watch for idiotic drivers, drive to the conditions of the road or 10-20% less, and look for people preoccupied with items other than driving are things that will save you. Even vehicles not towing have been know not to stop in time if there is a wreck in front of them.
By all means, if you are maxing out your tow rating INSTALL BRAKES! If you are new to towing, nervous about towing, live in a state that doesn't trust it's citizens; follow their laws. If brakes were required on every trailer, they would be sold with every trailer. The gub'ment would mandate it!
not on "the attack"...just pointing out the obvious...as you stated, trailer brakes may or may not make a difference, but common sense would dictate (or experience) that will ultimately be better off with brakes in the event of things going south. The person I quoted felt the 4runner would be fine WITHOUT trailer brakes with a 3000-4000 trailer...and I COMPLETELY disagree with that, and feel it is completely irresponsible to tow a load like that, with a truck like this, and rely on stock brakes.
I don't think you need a politician to point that out, your sense of personal responsibility to people you share the road with should help you make that decision.
