Cabin Air Filter Replacement Problem
claydoctor
OK, I was smart enough not to let the dealer change out cabin air filter . Easy to do yourself, right ? Watched the You Tube video. Piece of cake!
First step is remove Phillips head screw from dampener . No problem .Followed all the other instructions. No problem . Then just as I was about to remove the filthy filter , the dampener mechanism falls out onto the floor . That did not happen in the video . The dampener mechanism has two holes in it at the top but I cannot figure out what those holes attach to or how. And why two holes ? I've tired to look up there with flashlight but see nothing . Assuming someone has the answer , at what point do I reinsert the dampener ? Last step or before you snap the glove box tabs in ? Help !
Thank you. To quote Emily Latella (Gilda Radner), "never mind."
Figured it out. Still not sure why that dampener has three holes in it when you only use two .
