Can 01-02 t4r's switch to a 265-75-16 with out trac/vsc and abs lights lighting up?
xspsi6
I heard the vsc/trac and abs ecu is specific to stock 265-70-16 and anything else will trigger these lights but just heard that through the grape vine.
Good to know thanks for the confirmation it just seems as if anything seems to up set the vsc system which spits out a gang of annoying lights so just thought I would check before I buy new tires.
i always though that 265 size tires were standard size for sr5 and limited models... i've never had smaller tires than that on any of my 3rd gen's
That is stock size on the 01-02 4WD SR5s.
Also, I suggest you do the AndyMod 2.0 for the 01s+
You cut one wire and splice in a switch to turn off trac/vsc WITHOUT taking off ABS.
Mine is always off.
Mine is always off.
it's not the stock size. The stock size is 265/70/16, OP asked about 265/75's
For the record, the computers don't know what size tire you have, only how fast it is turning. If you pay me $50 I won't tell your ECM you changed sizes!
:keyboard:
:keyboard:
Pay me $100 and I will show you pics of an 01' with 265/75/16s and tell the ECM to not throw any vsc/trac or ABS lights.:wof:
zero point calibration
if the light does go crazy for whatever reason tires or not, isn't it just a zero point calibration to get it back to happy??
pax at 4
