Can I install sway bar relocation bracket with a Daystar Lift?
Whytey
Hi all,
In short can I install a sway bar relocation bracket on my 4runner while having only a Daystar 2.5/1.5 spacer Lift.
Last year when I installed my Daystar Spacer Lift I ended up having two welded nuts (one on each side) break loose inside the frame at the sway bar bushing mounting spots.
I was somehow able to hold a nut in place inside the frame and get a new bolt to tighten down on it. In the future I plan on installing a proper suspension Lift as well as install the poly bushings I currently have and will be needing to remove those bolts to do so.
To save myself some time on the next install I am wondering if I can preemptively install a sway bar relocation bracket with only the Daystar 2.5/1.5 spacer lift. I do not know if there is a minimum lift required. My guess is no but just thought i would check.
Normally required with a coilover setup. You only know when it hits the lower coil bucket. My Fox CO's came with relocation blocks.
H.Sikina
