Can I run 285s with 1” rear springs
GAsr5
Hi all,
Just ordered 285 ridge grapplers and 6112/5100 to go on in a couple weeks.
I already have the 1” bilstein b12 springs but I’m having second thoughts on if I will scrub.
I’d like to not have to chop or hack away at my 4Runner.
Will I need to get 1.5” or 2” or will these suffice.
I do 99% of my mileage on road.
yasssss. came here for this.
those tires fit stock.
but yes, the rear is perfectly fine.
I was actually reading some of your comments on another thread regarding Ironman suspension kits. Have any recommendations for someone like me preparing to get their first lift kit?
I want to run 285s with the most comfortable ride and ideally low maintenance. I don’t do any off roading. I don’t need anything high end like king but want something right in the middle.
basically they are saying u can run whatever size 285 you want in the rear stock, lifted, slammed, etc. Putting big tires in the rear isn't the problem.
Meaning what? I thought a higher lift in the rear plus the front being higher with the shocks would allow me to run a larger tire?
Am I missing something?
Until you start moving the bump stops and ball joints, all you are doing is changing your static ride height, the wheel travel is all the same.
