Can I sand blast?!
AF808fighter
I have rust on the rear axle, some on frame etc... I am about to have this taken care of permanently so I want to sand blast all of it, but can I have it done WITHOUT removing the frame and axle from the body? Ideally I want a sand blast-- acid bath--epoxy primer--undercoating. I've been using a wire wheel but its taking too long and can't reach certain areas.
Any insight would be appreciated on the sand blasting!
yeah just get a sheet of lexan from the hardware store and use it as s shield against your spray, cover up any lines or bushings and prepare for a massive mess but it still maybe quicker then removing the whole thing, that said if you do choose to remove it it will be a far better job when all is said and done, meaning you can get better angles with it removed and truly make sure all of it is coated as opposed with it still in your not getting the top of it as well and where ever the mounts are don't get done at all, if you look at a sand blasting chamber they just use lexan to protect you as well so just cut that stuff up and tape it into the spots where you need protection
DanielShawSZ
