goatfarmer
Need help, hopefully there's a remedy that is not too labor intensive? 90 T4r with auto.: First time this has happened where I made a few stops today and on each occasion I was unable to move the ignition key to the lock position without using the override button at the top of the center console. Once I returned home now I can not move the ignition key to the lock position, with or without using the override button, so now the key remains in the off position and I can not remove it???
Curious, if I leave the key in the off position will it drain the battery, noticed the clock is lite; whereas, don't believe it stays on with the key in the lock position. Suggestions/Comments appreciated.
