Can someone help me find the correct bulbs for ECT light and window switch light?
Supermoney
Recently my ECT light on the CLUSTER has burned out it appears, as well as my rear hatch window light that illuminates the button has also burned out.
Does anyone know the correct style bulbs for these two?
The bulb for the ECT light is labeled as "Toshiba V-2" and has a plastic twist on base. I have plenty if you want a couple.
I have a 2000 T4R LTD 4WD and my rig did not come with a light for the rear hatch switch. Are you talking about the switch that lowers and raises the rear window? The switch in the center dash console?
Yep, I have a 01, so should be the same. Mine was always lit up until recently.
erinobr2000
