Can someone recommend an air chuck?
hearno
Senior Member
My knees are tired of filling tires after a trail run. I want a chuck that clamps onto the valve stems that actually works. Can anyone recommend one? It'll attach to my ViAir compressor. Thanks.
I think any chuck that has the lever for the clamping device would work fine. Ive got a Milton air chuck at work, Amazon.com: Milton 693 Dual Head Straight Foot Air Chuck: Automotive. its got thread like teeth on the inside that grabs on to the valve stems threads. When you got to fill up a semi truck tire to 100psi, these are a must!! Especially for safety concerns just in case the tire decides to blow.
Thanks for the reply. So the one that you linked will hold onto the valve stem and I can walk away and let the compressor run?
Yes it does, all the way up to 120psi on a 445/50r22.5 wheel. Yes I have used these on my personal vehicles as well, but if you have rubber valve stems, it may take a toll on them as it may be too heavy for it.
