driffter33
sweet how do i get on the list for one of these bad boys???
Your on it!
Your on it!
Gotta make sure your antennae is grounded first, I couldn't hear anything until it was grounded.
Then you need to buy yourself a SWR meter if your CB doesn't have one built in. Then read these two awesome articles on why tuning is important, and how to do it
CB Antenna Tuning and SWR Explained
CB Antenna Tuning Guide
Your on it!
Hey guys, got a question for the more experienced (then me) radio guys. When i installed my drifter antenna mount, i ran a ground wire from the mount to where the tail light is grounded to the body and shared that ground screw. My problem is that when i use my brakes and the brake lights come on i get a bunch of static and noise from the cb and the rx signal strength meter gets pegged. Has anyone experienced this?
Im wondering if i should run the ground wire to a dedicated point on the body or chassi, sand the mount/location to bare metal (was hoping not to) or maybe look into the power supply side up at the head unit.
Thanks for any suggestions, im not really familiar with cb issues.
In case it matters, im running a cobra 18 wx st 2, 90' adapter, 18' coax, and a 4' firestick.
Hey I want to be on the list too! I'm tired of using my 1988 handheld CB. You got a lot of demand for your bracket. Let me know if need a production worker. :lookout:
Ive already pm'ed him with no response.![]()
I did too with the same outcome. Let me know if you hear from him. I am trying to get in on this as well.
Was going to just bite the bullet and get the ODL one but they are out of stock as well as toyotec
It looks like toyteclifts.com has the Outdoor Logic Antenna Mount. It does not say anything about being "out of stock". Just something i saw while bs-ing on the internet.
What kind of bulbs are you using for brake lights? If LED, try swapping to a regular bulb. Either that, or experiment with other ground locations. I get a similar interference issue with my LED reverse lights. As seldom as I reverse, I have not bothered with it.
