CB Install in a useless pocket
Okay, there is a formula, but it's not necessary to know the formula, just a good rule of thumb. Let the engineers worry about the formula. I follow a rule of thumb of 6 forward, 1 back. The means for every 6 watts forward (watts being transmitted), you want (at most) one watt reflected (coming back). I set up a repeater earlier this summer and when I tuned the antenna using my watt meter, I had 6 forward and 1/4 coming back. That was really tight! And that was on both transmit and receive.
If you think of a transmitting power like water.
When you're spraying a garden hose to water your flowers, you want all the water to hit the flowers. Just like transmitting a radio signal. You want all of the signal to get out to a repeater, another radio, etc... Now, let's say you're spraying the hose, but hitting the nice stone wall you put because you're not aiming (or in the case of the radio, tuned right), you're getting some water splashing and not getting on the flowers. You're still getting the flowers some, but not completely- that's what we call "reflective power". To correct that, you adjust the hose (antenna) to get more water (or in the radio's case-power out), and less coming back. Same with the water hose.
Does any of that make sense...
I do understand that, and the purpose, and what you have to do to get that flower the water and maximize. I think it was all the numbers/symbols/formula that was not computing in my peanut head. I guess that's why you guys go to college and make the easy BIG BUCKS.
Lame mans terms, when at your guys age, DON'T DO DRUGS.
So how do I do CB slang? Lol.
All i hear is a bunch of dudes talking in spanish and some static :mad2:
I just spent an hour getting you edumacated this far, now I have to spend tomorrow on slange GOOD BUDDY. Roger.
I imagine you want me to come over and talk on it for you too.:wtf:
EDIT: Welcome to the USA.
Not necessarily. The other thing is the ground plane is usually in a horizontal orientation. The vehicles I deal with use a direct mount to the roof of the vehicle that use the roof of the SUV as a ground plane.
Now that is what I understand , and have that principle down.
How many watts??
I have in my SUV a connex 4600 turbo, turned up a little more and some other things done on the electrical side to it. CB shop in Arizona did for me.
200+ range.
Got another on my shelf for my truck, couldn't keep in there due to the antenna kept getting knocked out of wack. Another connex 80+ watt.
I wired up my CB today with a PA and 3' firestik. After about 4 hours to install it, I accidentally keyed the mic while the antenna was in my trunk. I haven't SWR'd it yet so I don't know if i blew the finals and it's hard to hear anyone on CB because it's philly and I'm dead center of the city. Let's pray for the best when my SWR meter comes.
Anyway, here is the install. It's a midland compact unit. I had to cut out the bottom of the pocket thing and shove the CB in there and affix it with double stick interlocking tape (heavy duty velcro)
Parts list:
Midland CB-1 - 50
3' Firestik - 18
Comet rs720 mount - 32 shipped from cheapham.com
Firestik antenna stud (I want to say k4 or something like that, basic study with pl259 connector on bottom, no ground needed) - 8
Firestik antenna quick disconnect - 8
FIrestik heavy duty antenna spring - 10
18' coax cable (was JUST long enough, make sure no loops or weird bundles when you run it) - 9
Mic clip mount thing - 3 (haven't put this on yet, I got a black plastic one)
PA speaker - 7
Misc wiring, fuse tap (wired to fuse box), heat shrink etc, - had laying around
I installed the PA behind my grille. I'm thinking of making a mic stand out of some spare angle and double stick taping it in the space next to the CB and having the mic sit right above it.
Now, cut some plastic or ply wood and paint it black, to fill around the edges!
Eh, there isn't much exposed at all.
Still struggling with the Mic, not sure where I wanna clip it. I was gonna stick a corner brace (L) out next to the radio on the driverside and mount it to that but that winds up looking a little clunky. I may just throw it on the side of the console...
Just velcro it like a lot of others... that way its easilt removable.
Parts list:
Midland CB-1 - 50
3' Firestik - 18
PA speaker - 7
Hey what is the connector called so the antenna doesn't fall through? If that makes any sense.
Parts list:
Midland CB-1 - 50
3' Firestik - 18
PA speaker - 7
zak update this with part numbers please
I'll do it tomorrow - I'll link all the stuff I bought
bump for links in the first post for [MENTION=90013]HHIRunner[/MENTION] and [MENTION=93434]gshadow325[/MENTION]
BillM777
