Retrofit Source has a great DS2 Morimoto kit for just over $225 IIRC. I got all the gear for my retrofit from DDM for about the same price. Additional cost is paint, wiring, etc but these don't account for much.Nice job on the retrofits. They look awesome?
I haven’t spent any time researching a kit. About how much does it cost to do it? And do you have to start with a certain headlight? Mine have a bunch of lines on the lenses.
Looks good man!
How do you like those Hella horns?
Sent from my Pixel XL using Tapatalk
There are probably a dozen retrofit projector build threads out there, just search a bitDo you have a more in depth thread on this projector build? Looking to do something similar, thanks. Nice build by the way.
Sent from my SM-G930V using Tapatalk
Love the lights! Happy New Year!
Was there any special aiming that you had to do or was all the aiming from those goofy aiming screws?I've spent the last two days doing a projector retrofit. Everything came from the retrofit source and seems of good quality. This was my second retrofit job and each time has been a learning experience to say the least lol.
I started with a set of DEPO's with glass lenses, really impressed with the quality. Here they are stripped down and sanded ready for paint:
Here is the mockup and getting the projector mounted. Instead of the flimsy H4 conversion mount I decided to bolt these straight into the headlight assembly. This install would have been way easier without doing this but these projectors are mounted SOLID!
After getting everything fitted it was time to paint the assembly and shroud. I wrapped the projector in aluminum tape to prevent any light leakage.
Here it is with the shroud on:
On the car; I like this pic seeing the horns and the tranny cooler :whoo:
And all back together, don't mind the dented bumper, that will be replaced soon.
Tomorrow I need to spend some time getting them fine tuned in and adjusted right but the cutoff looks great, just a bit too low. Will follow up with pictures soon!
those lights came out real Good
They definitely fit the housing and look great. Nice job.
Awesome, man!
