Center Diff Lock Switch Question
405Runner
Hey there.
Took the 405Runner out today and was trying to get the center diff to lock. But no luck. I remember it working awhile back, but we haven't had much bad weather lately so never messed with it.
The light works, since it blinks when the 4WD is engaging.
So, I pulled the switch, and I don't have any continuity between any of the points when its neutral, or when I push it down. So I'm just thinking it's a bad switch. Looked all over the FSM but can't find a pin out for it or a test. Just wanted to see what others thought.
Edit: Guess I remembered wrong. I havent done anything under the dash other than a new ignition switch. So, guess I just remember the yellow ball blinking.
Hey there.
When you say switch are you talking about the button you push or one of the sensor switches on the transfer case/front diff?
Figured it out.
PO must have been in there messing around. There are 2 plugs that fit the switch. Finally sat down and found the switch in the wiring diagram and it said only a grey/white-black wire ran to it, the plug that was inserted had 4 wires, and it only had the white-blk wire. So, Plugged in the correct one, and bam-o works.
Bunkstaff
