Center Stack Lights Out
jbssfelix
So I opened up the HVAC/radio to change out a USB cord for my headunit, and after I put everything back together, a bunch of lights are now out....but not all of them.
So all the buttons and controls work, the radio works, the backlight for the HVAC dual climate screen works, the little orange arrows that show what HVAC setting you're on works, and the little square lights when the seat heater is on works.
Things that don't work...shifter light, the backlight for the seat heater knob itself, the cupholder backlights, the backlights for the HVAC labels, hazard button and rear window button. It was working before I reassembled everything, now they're all dead.
Checked fuses and everything seems okay. Any ideas?
Maybe a fuse, or loose connection, check fuses, if no bad fuses, remove what you need too to access the area you were working around and check all wiring and harness connections.
