Charcoal canister location on 2002 4runner?
bobs2002
A friend of mine has a 2002 4runner and has had problems filling the gas tank--the pump nozzle continually shuts off after only a few seconds. We checked it out online and found out one possible cause could be a clogged hose connected to the charcoal canister.
Where is the charcoal canister located on her 4runner?
its on the drivers side by the battery looks like so
p0446 CEL light
Thanks Elton.
Anyone else have this issue?
i have this too. sucks. trying the charcoal canister as it seems to be the root of most people's threads i've come across. they are expensive though. so I'm trying a used one. never had this problem on my 99' 4runner... and it had over 261k on it...
Interesting...... I have been slowly feeding the the tank for years. I always thought the filler neck shape was the issue with the pump nozzle continuously shutting off.
Sub for results
Regards .... 8sm
I've experienced this issue occasionally about a month after I installed my lift. Thought maybe the lift may have contributed to the issue but probably just a coincidence. I have noticed that as long as i don't put the pump nozzle all the way in, maybe just 3/4 of the way in, the pump doesn't shut off. Not sure what that's all about but haven't experienced the pump shutting off since I started doing that.
I experienced this too about a month ago but only for 1 or 2 fills after I routed new trailer wiring on my 01 (it travels on rear left side by that air passage near the left side of bumper) perhaps a coincidence, i tried using different filling stations and that seemed to help. Then eventually ended back at the 'offending' pumps and no more. Maybe the beginning of something bigger. :cowboy:
Found the hose attached to the factory air box. Blew through it and cleared it out. Not hard but not sure it did much since when i filled up it stopped once. Guess its a little better? Hard to tell with only one fill.
Tx470
