Chasing a front end shake.
Glad that fixed it for you.
I'm 500 miles from my old home and 500 miles from my new home currently.
I'll get them remounted correctly next week.
Just hoping to make it there without overheating.
ThisToyota has been a serious lemon... but it's still running with some mountains and hills upcoming so saying prayers
Yikes! Also praying for your cell coverage!
I'll check this out.
Found out firestone didn't balance the new tires well.
All 4 were out of balance. Drives better
Just a got reply from falken after I left and apparently the paint dots are for specific mounting and balancing positions so they will need redone again
Hence why I've only had my tires balanced and aligned by Toyota...
I do all my work at home that doesn't require special equipment, the rest is done by the car's manufacturer. That's how I do things now and I never have repair issues.
So does that explain why the Toyota dealer replaced the entire cooling system and now it runs 20° hotter?
I have had very bad luck with Toyota service department's
Having the tires remounted and re balanced for the third time.
Truck seems to roll smooth but once the tires warm up it gets loose again.
Already talked with falken and if they need rebalanced again, I will get a new set sent to me
Hindsight, I should have gone with a tested tire like the KO2.
I thought it was my front end but it's worse now and this is the third time all tires have had to b balanced in the first 1300 miles.
Any tire company can have problems with a few sets of tires, i believe the KO2s have had balancing problems also. Sounds like Falken is stepping up, so thats a good step in the right direction. I just had 265/75/16 Falken MTs put on last month, and have had no problems so far, i like em alot. Good luck my friend.
