check engine light and cats
janesvilledave
hi, I have an '03 4runner, v6. The check engine light and vsc and vsc off lights came on. Took it to a dealer and they said the codes indicated that the catalytic convertors were bad. The price for replacement came in around $1900 dollars. Before i do anything, would appreciate any and all feeback on this issue, the truck runs fine, the mpg indicator shows an average of 21 mpg. What shold i do? thanks, dave.
Hey,
I have a few questions for you. I worked as a service advisor for toyota for many years.
How much milage is on the truck
The federal govt requires all auto manufacturers to warranty emissions devices for 8/80,000 or 10/100,00 I cannot recall which.
Second, the truck seems to be running fine from what you say, what grade fuel are you running. I have seen vehicles throw a check engine light from a boderline cat when running regular fuel. Changing up a grade or two stops the light.
My first question is most important, they hace to cover the cats, 02sensors and alot of emissions devices. I can contact my friends at toyota if need be.
AK, the 4runner has 118,000 miles, and the emissions system is out of warranty. I only run regular 87 octane fuel, I will try a higher octane as you recommend and see what happens. I was also wondering is anything else can trip the check engine light that might lead to a false read on the cats, replacement is so expensive as the cats are in the two front pipes, they also are pricing in new oxygen sensors just to be sure. I called a local meinecke shop and they said they can replace the cats for around $450.; i believe they will cut them out and weld in new ones. I really do not want to do that. I apppreciate your response, thank you, anything else you can add please do. dave.
Do you know what the code was exactly? Sounds like they don't know if it is a bad sensor, or a working sensor, and bad cat(s).
They want to replace both cats, and both after cat O2s? Or are we talking just one bank?
Dave,
Try the fuel first. I never really liked aftermarket catalytic converters. They have a precise job, not like a muffler. Up the fuel and drive it for a bit. See where it takes you.
Aron
I agree, it could be one bad sensor and the dealer is changing the whole shabang because thats what they do.. I know all to well, I used to have to sell the stuff. Thats why I changed jobs, I needed to be able to sleep at night.
Sorry for taking so long to get back to the posts. I took the 4runner to a local meinecke shop, with their diagnostic equipment they said that one of the downstream sensors was shorting out. I replaced all the sensors (both air/fuel and both O2); they were right, check engine light is off. Cost of parts and labor about $500 Warning: I took the 4runner to two different toyota garages, both said codes indicated weak cats; their estimates were $1900 nd $2200 for replacement; the $2200 estimate included replacing all four sensors too. I have received help over this forum and hope this post will help someone too.
Talyn
