Check Engine Light intermittently comes on and off, for almost a year.
Done the following:
1. Replaced Bank 1 Exhaust Catalytic converter manifold. (with Used one, from reputable Ebay dealer, who says it is good working order.)
2. Replaced Up& Down Stream Bank 1 O2 sensors.
3. Ran cataclean in fuel system.
Same results, but Check Engline Light stays off longer since doing the above. got 400 miles before light came back on after replacing O2 sensors.Now its Back on again. It will go out again, and repeat the issue. ON for awhile, OFF for awhile.
Can anyone confirm: If the Catalytic Converter is truly the cause, wouldn't the Check Engine light stay on constantly? As my issue is Intermittent P0420 code. (Catalyst System Efficiency Below Threshold Bank 1.)
I dont want to be replacing the Cat with a New one if we Don't have too.
Other possible reasons:
Air Fuel Ratio Sensor?
Mass Air Flow Sensor MAF?
Reset Engine Control Module (ECM w/C1201, C1223) ?
Exhause Leaks? Bad Exhaust Gaskets?
Done the following:
