Build a Toyota | Build a Custom Toyota Vehicle Package
I'm not sure I understand the differences between these 3:
(1) 4x2 (RWD) has limited slip differential. OK.
(2) part-time 4WD does not have limited slip differential?
(3) full-time 4WD has a locking center differential. How about limited slip differentials?
I am thinking of going with option (2), and I'm wondering if (2) is in some aspects inferior to (1). I can't afford a Limited (option (3))
If you look at the "Part-Time 4WD: There When You Need It, Not When You Don’t" section of [MENTION=66316]1engineer[/MENTION] 's post.. you will see a lot better explanation of the way the 4runner operates. I agree with [MENTION=1032]NoDak[/MENTION] above. You have posted a few other places on the forums, and I think that you would be best to go with an SR5 4x4. But ultimately it is your decision.
It is not as simple as "it does"/"does not" have limited slip differential. The SR5 and Trail versions have "part time" 4wd, that is activate by a mechanical gear shifter. The Limited has "full time" 4wd.
Both the trail and the SR5 4x4 have ATRAC, but the trail has a "multi-mode" dial for the ATRAC that you can select different terrain choices for the ATRAC to react differently on different terrain, or you can turn it off. The SR5 has just one standard setting for ATRAC, and is either on or off.
The trail has an option to have KDSS. The SR5 does not.
The trail has "Crawl Control" (a low speed "auto drive" function), the SR5 does not.
The trail has a button activated electronic rear differential lock. The SR5 does not.
If you decide, you can also go with a "Premium" level on the SR5 and the Trail Edition, and it adds other features, like sunroof and some other sound system/navigation upgrades.
If anyone sees something wrong here with my description let me know.
There might be some options that can be had with SR5 I am not aware of, but I think I got it right.
