Cigarette outlet chargers not working
Mtneer001
I have a 2006 Toyota 4Runner.
Just recently, my cigarett outlet chargers stopped working. I checked the fuses and they seem to be ok.
Any suggestions on what to try next without having to go to the dealership?
Thanks.
Do you have the smoker's kit? That's the one with the extra charger/lighter and the ashtray receptacle in the console. If that's what stopped working, I'd take the console apart (it's pretty easy) and make sure you don't have a broken wire or a connector that's pulled out.
If it's the 12v power outlet in the front and also the one in the rear, I believe there is a common relay that both of those go through. It's the same relay that you have to put a jumper in to do the 12v constant-on modification, which you should be able to do with a quick search on the forum.
Mine front one and the one in the rear trunk quit and it was the fuse. Try a new one even if it looks fine
Jhunt
