Cladding question
bowrappyo
Hi,
I currently have a Jade Mica/Oak 4runner with arb bumper. I am looking into painting the limited cladding either jade mica or just a semi-gloss black. Another option I am looking at is finding black cladding from an SR5 Sport, ala highlander 4runners but have a couple of questions.
1) has anyboy replaced the limited cladding with the less bulky SR5 sport cladding? Is it a direct bolt on?
2) thoughts on painiting limited cladding black and or green? any suggestions of where to go in Los Angeles area?
3) should I just plasti dip the cladding?
Thank gang!
Won't bolt on.
I'd say leave it alone. I like the cladding.
If you want, but it won't last. Or look good.
Won't bolt on.
I have to disagree with number 3. Well half of it.
Does it look good, yes
Will it last. No. Especially in the door sill areas. But I will be adding those vinyl door sill protectors to take care of that.
It was nice to see what it would look like all black. Took 4-5 cans of plasti dip. About a can per coat. Just don’t try and cover on the first coat. The first coat should be light. Just enough to bond to the plastic cladding. Then build up the coverage with each coat from there.
You did a good job sir! Looks pretty solid. with the matte/gloss black combo. vader.
Just to expand a little. Removing the lower door cladding on a limited will expose a bunch of holes in the doors. It is possible (and people have done it), but you'd have to close up those holes or replace the doors. Far easier to go from non-limited cladding to limited cladding than vice versa.
